  • 1994 - 1995 Specific Tech
Oil Pressure ?'s
  • Thread starter Thread starter WhiteDevil
  • Start date Start date Dec 1, 2006
WhiteDevil
2,717
San Diego
Dec 1, 2006
  • Dec 1, 2006
Well the 347 has 2,000 miles on it now and i just had a quick question about oil pressures. On cold start up i get about 52-53psi and it stays there at idle or driving. Once the car has been warmed up for a while it will be at 50psi steady while cruising. Once hot at idle it drops to around 27psi. Right when i hit the gas it goes back to 50psi. I just wanted to make sure this is normal
WhiteDevil
2,717
San Diego
Dec 1, 2006
  • Dec 1, 2006
anyone?
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Dec 2, 2006
  • Dec 2, 2006
seems normal IMO
Killercanary
The car that set the bar.
Altoona, PA
Dec 2, 2006
  • Dec 2, 2006
Seems OK to me. Its just your oil thinning out when warm, and the pressure comes back with RPm as the pump spins faster.
My old stock 302 would drop to 10psi or lower at idle right before I hurt it. It was nice and loose!
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Dec 2, 2006
  • Dec 2, 2006
I would crap myself if that happened to me.
JP, my pressure is about the same as yours. They're supposed to fluctuate like that. But mine only drops about 5 psi at idle. I'm not saying you have bad pressure, though .... I have no idea. What pump did you put in there?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Dec 2, 2006
  • Dec 2, 2006
Sounds OK to me John
Grady
4Jenna
4,326
AZ
Dec 3, 2006
  • Dec 3, 2006
HV pump?
If so thats much lower than mine (HV Melling)
blksn955.o
3,263
st.louis mo 314
Dec 3, 2006
  • Dec 3, 2006
Mine is EXACTLY like that with the std. volume pump on my DSS pro bullit 306. I have somewere around 3-5k miles on it (speedo/odo way off)
WhiteDevil
2,717
San Diego
Dec 3, 2006
  • Dec 3, 2006
Mine is a blueprinted melling stock volume pump. About 2,000 miles on the stroker now. Dyno next saturday! Thanks guys
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Dec 3, 2006
#10
  • Dec 3, 2006
  • #10
That doesn't sound bad to me personally. What weight of oil are you running through it?
WhiteDevil
2,717
San Diego
Dec 3, 2006
#11
  • Dec 3, 2006
  • #11
10W40 Castrol right now for another 1,000 miles. Then it will be 15W50 Mobil 1 Full Synthetic.
OrangeMustangGt
1,976
Cape Cod, MA
Dec 3, 2006
#12
  • Dec 3, 2006
  • #12
yup, i just put a cheepo mechanical oil pressure gauge on my bronco. It does the same thing. 50 cold, 25 warm cruising, and 10 at idle warm
Grn92LX
Fidanza Man!
6,819
64
129
New York
Dec 3, 2006
#13
  • Dec 3, 2006
  • #13
Why are you waiting so long for synthetic?
Post up the dyno #'s after you go. Good luck.
DDSTANG94
465
FRASER, MICHIGAN
Dec 9, 2006
#14
  • Dec 9, 2006
  • #14
THIS IS NOT NORMAL. IT SOUNDS LIKE YOUR BEARINGS ARE ALREADY WORN OUT.
SQUEEZE&STROKE
SOUTHERN CA
Dec 11, 2006
#15
  • Dec 11, 2006
  • #15
That is PLENTY of oil pressure...right around what my 331 runs at. Dont be scared, the std volume pumps have been recommended by everyone I have talked to...you dont need the HV pump it robs power.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
J
Lack of power on acceleration
  • jameshernandez
  • Aug 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2026
jameshernandez
J
