Oil Pressure Sending Unit
  • Thread starter Thread starter 67chad
  • Start date Start date Apr 4, 2006
67chad
25
  • Apr 4, 2006
All this talk about oil pressure reminded me that my sending unit never worked for me. I rebuilt my engine 4 years ago and added a HV oil pump, I know I didn’t need it but sounded good at the time. I also replaced the sending unit with the proper 67 289 unit but it never would read pressure. I have since replaced it two more times each time the gauge would work at first then stop. Is the stock sending unit only good for low pressure? If so what sending unit could I use to replace it? I will be changing out to Autometer Gauges soon so I am sure that will fix the problem but I have always wondered what was up. Thanks for your time.
67chad
25
  • Apr 5, 2006
come on i know someone out there has an idea thanks,
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Apr 5, 2006
  • Apr 5, 2006
the stock sender is fine, I would assume you havea gauge or a wiring problem.
67CoupeDriva
165
South Carolina
Apr 5, 2006
  • Apr 5, 2006
A question from Mr. Obvious...but did you get the right kind of sender for your gauge? The idiot light (Tach cluster) and pressure gauge use different senders.
Otherwise, test your gauge and the wiring to be 100% sure it's the sender at fault.
LMan
1,246
Mom's basement
Apr 5, 2006
  • Apr 5, 2006
As you say, when you change it for a quality mechanical gauge, your sender problems are in the past.
I agree with Worth about the wiring. But I'd think the stock gauge is only good to show *some* pressure exists; you cannot really tell what the value is, so the benefit is minimal anyway.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
