Oil Pressure
  • Thread starter Thread starter Mavrick
  • Start date Start date Aug 3, 2004
Mavrick
2,264
Collingwood, ON
Aug 3, 2004
  • Aug 3, 2004
Got my new autometer oil pressure gauge installed, and im just wondering how much pressure i should have?
Right now im running 10w30 non synthetic and when cold, i get 50psi at idle, but after the motor is above 160degree's or so, i get 19/20psi at idle, and plenty when i rev it up.
Is 20psi at idle normal?
stangbear427
2,401
New England
Aug 3, 2004
  • Aug 3, 2004
Probably. How many miles on the engine? That makes a considerable difference. General rule of thumb, you want at least 10psi per 1000RPM to be safe. More is fine. Synthetic actually acts like a thinner viscosity than the corresponding conventional oil, so it would be normal, especially in a higher mileage engine (100K+) for it to be a little lower than it would have with normal oil of the same weight. As long as you aren't getting blowby (does it smoke?) you should be fine with those numbers.
Mavrick
2,264
Collingwood, ON
Aug 3, 2004
  • Aug 3, 2004
I'm using regular non-synthetic oil. Top end was rebuilt less than 1000km ago.. but the bottom end was not touched (previous owner).
stangbear427
2,401
New England
Aug 3, 2004
  • Aug 3, 2004
Oops, non syth. I musta read your post too fast. I'd still say your fine, 20 is normal at idle.
stangbear427
2,401
New England
Aug 3, 2004
  • Aug 3, 2004
delete
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
