oil pressure?
Welcome to SN. :nice:
Stock gauge? I would replace the sender if it has not been renewed recently. Better yet would be to get a real gauge for your piece of mind. :) The stockers are almost useless.
Good luck.
As Hissin stated: The stock gauges are more for show than actually monitoring your engines vital signs.
My stocker drops when I am at idle and then moves up when I am cruising down the road. I don't really trust it and will probably put a autometer under the radio this winter...
How many miles on your car if you don't mind me asking?
the guy who had it before me put white face guages in it. when i first got it the needle stayed in one spot but after about a year or so it dropped some. if i was to get a different guage what would u recomend?
and as far as the mileage im not sure my speedometer hasent worked in about 6 months.
The more milage on the motor (if abused) will allow the bearing clearances to increase. This means you need more oil to 'fill' the gaps on the rotating assembly and this can cause a drop in oil pressure.
For gauges... Autometer is probably the most common. Either electric or Mechanical will be much beter than stock
Yep, any gauge out there (almost) is much better than stock. AM, VDO, Stewart, Smith, Magnetti Marelli, et al are all very good gauges.
AM is the most popular and very nice stuff.
Good luck.
I have a similar issue coming up and I have a pretty good feeling it isn't a bad guage. It has shown consistency on the oil pressure guage the entire time I have had the car. It is getting (over time) lower and lower...just little by little. I have 155k on the engine.
