blackjack21 New Member Aug 11, 2008 34 0 0 GA Aug 21, 2008 #1 Aug 21, 2008 #1 when you turn the key to the "on" position, does the oil pump start moving oil at all?
A alf1096 New Member Aug 12, 2008 21 0 0 Aug 21, 2008 #2 Aug 21, 2008 #2 The oil pump is mechanical and will not start pumping until the engine is started...The fuel pump will turn on with the key.
UrbanRedneck New Member Mar 27, 2008 173 0 0 Aug 21, 2008 #3 Aug 21, 2008 #3 alf1096 said: The oil pump is mechanical and will not start pumping until the engine is started...The fuel pump will turn on with the key. Click to expand... Like he said, the oil pump is driven mechanically by the engine. I think it is mounted on the front of the crankshaft if I remember correctly. It's been a while since I've had a mod motor apart.
