oil problem?
  • Thread starter Thread starter xYoung347x
  • Start date Start date Apr 23, 2004
xYoung347x
382
  • Apr 23, 2004
*To start off, I have a 1994 gt if it matters* My oil pressure is high when my speed is up but when I come to a stop the needle goes all the way in between the N and the line in NORMAL than it goes back up high again. What is going on here?
_jb_
808
Michigan, Berrien County
Apr 23, 2004
  • Apr 23, 2004
There is no need for high oil pressure at idle speeds. A thicker oil may help this though, and it wouldn't be a bad idea with summer coming around. The OEM guages are known for being inaccurate, but as long as you don't hear the lifters rattling, there is oil being circulated.
Best thing to do is to get away from the OEM gauges and get something like AutoMeter.
dvsmike
70
Chicago il
Apr 24, 2004
  • Apr 24, 2004
ttt
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Apr 24, 2004
  • Apr 24, 2004
A general rule of thumb is at least 10 psi for each 1000 rpm (60 psi at 6000), with at least 20-25 at hot idle. But you have another issue - you don't really know what your pressure is with the stock gauge. You only know the needle is moving around. I'd invest in a quality oil pressure gauge so you know what you're dealing with. Only then can you begin to diagnose oil pressure issues - you may find you have no problem at all. Get a good sender/gauge.
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 3:55 AM
manicmechanic007
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
