oil pump install
The oil pump is mounted on the crankshaft behind the timing cover. It is completely within the oil pan. It is not possible to replace the oil pick-up tube without removing the oil pan.
The on vehicle service procedure to remove the oil pan involves supporting the engine, disconnecting the motor mounts, and supporting/lowering the front sub frame (from 2003 Mustang GT service manual).
I am sure having a lift would be a great help.
