  • 1994 - 1995 Specific Tech
oil question
  • Thread starter Thread starter deadlast
  • Start date Start date May 9, 2005
deadlast
495
Belmont, MA
May 9, 2005
  • May 9, 2005
iv never changer my own oil and i just questioned why the hell dont i? where is the drain plug located on the pan? how much oil should i refill it with and are there any specific brands that are good. lastly where can i take my used oil?
JJ95GTID
1,141
Phoenix, AZ
May 9, 2005
  • May 9, 2005
There are two drain plugs/bolts on the bottom of the oil pan. Once you get under the car you'll notice the oil pan has two humps in it. There is a bolt on each hump to drain the oil.
I buy a 5 quart jug of oil at WalMart. I like the Castrol Syntec 5W30 but opinions vary on what type and weight of oil to use. You can take your used oil to Jiffy lube or a place that does oil changes. Just don't mix the oil with gas or coolant and they will take it.
HISSIN50
34
129
May 9, 2005
  • May 9, 2005
a repair manual will really help you out with doing routing maintenance like this, if you choose to start doing it. the books are worth it for torque specs alone.
good luck.
Q
qwick94GT
108
  • May 9, 2005
I use Mobil 1 Synthetic oil. I used to use Castrol, until my buddy took his engine apart one day after about 100,000 miles of nothing but Mobil you could still see the hatch marks on the inside of the cylinder walls like they were a day old.
Also DON'T use a high volume Oil Filter like a K&N on a mostly stock engine. A Motorcraft filter will do just fine.
slytherin
702
northeast ohio
May 10, 2005
  • May 10, 2005
Walmart is about the best place to get oil of any kind/brand.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Engine How does oil make its way into the front sump?
  • Sock_Monke
  • May 10, 2025
Fox 5.0 Mustang Tech May 22, 2025
Chuckster101
C
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
