  • 1994 - 1995 Specific Tech
Ok...Load or Loadx
  • Thread starter Thread starter Methodical
  • Start date Start date Feb 6, 2006
Methodical
1,192
11
59
Clinton, MD
Feb 6, 2006
  • Feb 6, 2006
At idle load is 17xxx and loadx is 27xxx. I've researched and found out load should be at or around 20%. Also, the readings states that Loadx is really Load :? . Which Load do I look for to be around 20%? Oh yeah I also read that you can adjust this by changing the size of the motor but not the best way. The correct way is the Sea level load scaling. Which load do I look at to be around 20%.
Thanks
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 6, 2006
  • Feb 6, 2006
Al
As I understand it, the Load Switch Scalar is what determines if you use Load or LoadX or as some have called it, Load%.
Scalar = 0 use LoadX
Scalar = 1 or 2 use Load
A couple of stock cal file Load Switch examples are:
t4m0 = 2
j4j1 = 0
Grady
Methodical
1,192
11
59
Clinton, MD
Feb 6, 2006
  • Feb 6, 2006
final5-0 said:
Al
t4m0 = 2
j4j1 = 0
Grady
Got it very simple and straight to the point. I like that. Now Loadx is at 27% at idle. Can I just up the CID in the scalar a little to correct or should I do the Sea Level Load.
Thanks Grady
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 6, 2006
  • Feb 6, 2006
Thanks Grady
I've not had any experience with either of your Q's
I currently idle at around 25% load and even that is a little bit high
I don't think that value is off enough to make me wanna fool with all that other stuff. I have looked into the load scaling thing a couple times but just blew it off.
I've already got my fuel & spark tables to my liking
so
I just ain't gonna mess with it
Have you already bumped up your cubic inch size to 306?
Grady
Methodical
1,192
11
59
Clinton, MD
Feb 7, 2006
  • Feb 7, 2006
so
Grady
Yes I have it at 306. But I will check to make sure I did not change the settings.
Thanks
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 9:17 AM
keel
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
