One Headlight Low Beam Works Passanger
my passanger headlight works low beam. my driver low beam works and my highbeams works good on both what can be the problem???? the headlight bulb is good checked that checked the fuses and have a brand new multifunction switch so it cant be that... anything to help
thanks in advance
thanks in advance
the passenger side low beams work
the driver side low beams work
the high beams work on both sides
i see no problem? :shrug: but i doubt you made a thread about no problem. the title of this thread makes me think you have ONE headlight.
edit: yeah i read it over and over....i don't see the problem here....
Through deciphering the post, GTosu solved the issue. :D
I read it the same way.
Now for hypotheticals: If you're missing a low beam, check the low beam wiring where it splits off at the front clip. It's often easier to just run a new wire from the driver's side where the harness splits in two.
