One inch drop?
  • Thread starter Thread starter shepscott
  • Start date Start date Jun 30, 2006
shepscott
  • Jun 30, 2006
Should/ can you do the one inch drop with the lowering springs? Or is it better to just do one or the other?
2bav8
2,511
Mesa, AZ
Jun 30, 2006
  • Jun 30, 2006
The upper arm drop increases negative camber when cornering to increase grip and traction. Its a no-brainer if you don't mind taking a drill to your car.
The coil springs are a good idea to reduce the CG of your car.
Together, the upper arm drop and lower coil springs work very well together. Add a few other misc parts like roller spring perches, adjustable strut rods and you'll have a very good handling Mustang.
G
grego37
576
Fresno CA
Jun 30, 2006
  • Jun 30, 2006
I did both, and love it.
if you do the drop, be sure to use the proper template.
mfp4073
387
Hells Ditch, FL
Jun 30, 2006
  • Jun 30, 2006
Its important to realize, that the shelby "1 inch drop" does not lower the car 1", it moves the upper control arm location by 1". Your net gain is less than 1/4", but the purpose of this is not to lower the center of gravity of the car. Rather its to change the way the suspension moves under cornering. Effectively leaning the top of the wheel in as the weight is transfered to it, thus creating a better contact patch.
Cupid
162
  • Jun 30, 2006
If you do decide to do both, make sure your headers aren't much lower than your frame rail....trust me, it sucks... Speed bumbs are not our friend.
2bav8
2,511
Mesa, AZ
Jun 30, 2006
  • Jun 30, 2006
This is true, Kingsford is getting a new set of headers after 12+ years.
Seems my auto-x addiction has required the need for headers with more ground clearance as of late.
1965 mustang 351 850 hp+ primary tubes 1 7/8 or larger and a 3 inch or larger collectors?
  • 427nostang
  • Jun 4, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 7, 2026
DadLife0724
68 coupe rear drop
  • Butchd88
  • Apr 3, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 19, 2026
C.R.M.
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
Flywheel
  • Barry
  • Mar 10, 2026
1974 - 1978 Mustang II Talk & Tech Mar 11, 2026
Barry
D
4.6L 4v motor swap
  • DangStitches
  • Jul 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 29, 2026
squeak93
