On the face of it you'd get almost precisely a 1/4" drop. But let's start at the beginning. Were the 5 leafs your choice? Whose are they, what brand and rate? If not sure just say so. If you post some close up pics of the rebound clips, top and bottom, and the leaf ends too, I may recognize what they are. The only maker of very close to original factory springs is Eaton Detroit, right down to the type of spring steel used, and no originals were 5 leaf. A side view pic of your car would be helpful too. We can discuss spring rates later, but respond to the above and we'll go from there. Simply installing lowering blocks (the shallower the better) can solve a visual ride height issue, but they aren't recommended. You want the springs as close to the axle housing as practicable, lowering blocks move them further away.
