one missing O2 sensor.
  • Thread starter Thread starter TrophyHead
  • Start date Start date Dec 4, 2005
TrophyHead
1,195
11
49
PA
Dec 4, 2005
  • Dec 4, 2005
Is it ok to replace just one O2 sensor? And leave the other still intact. Will I run into any promblems?
HISSIN50
34
129
Dec 4, 2005
  • Dec 4, 2005
It is best to replace both in pairs, but folks replace one (and leave the old one on the other side) all the time.
Good luck.
TrophyHead
1,195
11
49
PA
Dec 4, 2005
  • Dec 4, 2005
Thanks I guess I'll replace both but dame Motorcraft's are $$$$.
What are the O2 sensors reading? Or what are they telling the computer to do?
sgarlic
3,085
Dec 4, 2005
  • Dec 4, 2005
You could find them much cheaper by getting a hold of Randy Stinchcomb either here or at Modular Depot.
The front ones measure the air/fuel ratio in your exhaust, and send signals back to the PCM to tell it to adjust by going lean/rich.
The rear ones (can't remember if foxbody's have them but SN-95's do,) monitor the efficiency of the catalyst system, and report it back to the PCM in form of certain voltage.. (yes it's working, or no it's not.)
HISSIN50
34
129
Dec 4, 2005
  • Dec 4, 2005
Andy is kinda thinking of his nice '04. Foxes only have two O2's (4 O2's are for OBD-II cars with the catalyst monitoring, like he said).
Autozone should have Bosch O2's for around 40 bucks each. And some guys get theirs from a site similar to
oxygensensors.com (not sure if that is exactly correct).
You really could be alright just doing one, so long as the other one still works halfway decently (what happened to the bad one?).
Just like Andy said, they just relate exhaust info to the puter so the air fuel ratio can be trimmed.
TrophyHead
1,195
11
49
PA
Dec 4, 2005
  • Dec 4, 2005
I snapped it off accidentely when I was installing my Tremec. Was in a hurry to try the new tranny out. Parts store was closed so I said I'll get to it in the winter time.
It's been bugging me for the past 3 months now. Car did run fine without it.
HISSIN50
34
129
Dec 5, 2005
  • Dec 5, 2005
I gotcha. I thought it might have failed for some reason, in which case the other one might not be far behind. You should be able to just replace one (you can always swap in the other one at a later time if you want).
It is funny - they do run pretty decent with no O2's. The slight increase in fuel economy is kinda nice though.
Good luck.
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
