One more supercharger install problem
  • Thread starter Thread starter bentley429
  • Start date Start date Sep 20, 2005
bentley429
Banned
Nov 25, 2004
528
Connecticut
Sep 20, 2005
  • Sep 20, 2005
After running the car for alittle while after the supercharger install I noticed that the belt rode over the AC pulley. Any ideas?
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Sep 20, 2005
  • Sep 20, 2005
Going to have to explain this one. The belt rode off the ac pulley? Your supercharge belt should go from the crank to the s/c - no accessories.
Rick 91GT
Mustang Master
95
99
PA
Sep 21, 2005
  • Sep 21, 2005
Check for proper belt tension, belt length and make sure everything is alignment.
bentley429
Banned
Nov 25, 2004
528
Connecticut
Sep 21, 2005
  • Sep 21, 2005
Right, I mean the orignal belt that goes to the other accessories.
cjuroff
75
Indiana
Sep 21, 2005
  • Sep 21, 2005
I had the same issue. It was the tensioner I ended up having to grind some of the water pump bracket done a little to keep everything in align.
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Sep 21, 2005
  • Sep 21, 2005
Did you correctly space the new tensioner re-location bracket? They provide you with some washers to shim the bracket.
bentley429
Banned
Nov 25, 2004
528
Connecticut
Sep 21, 2005
  • Sep 21, 2005
Bought the setup used so I didnt get any washers, I figured thats what the problem was. Thanks for the input guys.
Killer50stang
632
  • Sep 21, 2005
got a picture? I had fun with my setup...
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Sep 21, 2005
  • Sep 21, 2005
i have the same problem with my novi. i have had the blowere on and off the car a few times and one of the times everything lined up perfect... i took it off and put it back on and the pulleys were off by one or two ribs(i used a laser level to check it) but the belt dosent jump off or anything so im not that worried about it. try some shims and also the laser level really helps out a ton i would try that out
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Engine Underdrive pulleys
  • Mindseye007
  • Feb 1, 2026
Fox 5.0 Mustang Tech Feb 14, 2026
Willybill32
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
