The red optima will be my replacement battery. I would like to use the billitt battery hold down. Who sells these? Also, are the Optima's a pain to install? Any modifying?
Thanks
Thanks
Intercooler is in the lower portion of the front bumper. Current battery is in stock position..no interference next to or around it. I could keep it simple and use a Ford battery, but I like the billitt tray & the red Optima set up.98blackmagic said:Your battery isint relocated in the trunk now? Dont you have the intercooler on your car with your Procharger?
xseler8 said:Current battery is in stock position..no interference next to or around it. I could keep it simple and use a Ford battery, but I like the billitt tray & the red Optima set up.
Thanks98blackmagic said:Ok, I just assumed that you had already put it in the trunk. Check out www.UPRproducts.com they carry a LOT of billte stuff and may have what you want.![]()
xseler8 said:UPR doesn't handle the batt holders. I saw them again & again in magazines,but you know the story..can't find it when it's show time.
.Thanks, that's good. There's another I want to look at also but this is OK.5.0's 4 ever said:Might want to try Aerospace Components
http://www.aerospacecomponents.com/battery_holder.htm
Green&GoldGT said:My cousin had an Optima battery on his cobra and he had to make some custom mounts from bare metal to fix it. BTW he had a weiand customs battery tray from ebay that looked awesome with optimas.
you need this91LX_5L said:You guys arnt talking about trunk mounted are you? Did that weiand not work for the optima?
I got a optima yeller top and right now its just chillin in my battery tray not held down, I need some method to hold it down as well but I dont want to spend like $150 on a damn tray?!
urban96 said:
