Optimal A/F ratio
QDRHRSE
1,590
Palmdale, CA
What is the optimal A/F ratio? I was talking to Dennis @ Central Coast Mustang and he told me that chips and aftermarket computer controllers/programers are ok, but for racing, the FMS SVO extender is really the best thing to get because its the only computer add on that you can dial in your A/F ratio with. He runs 8's with one and a stock ECU. Anyway, I bought one fore the heck of it. I'm ashamed to admit that I don't know what I should set the A/F ratio at. 11.5:1-12.5:1???? Help a brother out.
Well.. there is no such thing as the perfect A/F ratio.
It all depends on what your goals are.
For maximum fuel economy, 15.5:1 is generally used (leaner would be better but you often run into problems getting the mixture to ignite)
For Maximum power, 12.5:1 is generally used.
For the best compromise between power and economy, 14.7:1 is what is used. 14.7:1 is what the factory computer tries to achieve with EGO correction....until you floor it, then the computer ignores the O2 sensor and dumps in more fuel.
Of course, these numbers vary from engine to engine, but they are usually pretty close.
From my days as an aircraft mechanic - 12.5:1 = rich best power - the excess fuel cools the engine. Run 13.5:1 for max power and with a very little extra fuel for cooling.
Ford's spec of 14.7:1 was the perfect ratio to burn all of the fuel and have no excess air - Stoichiometric ratio is what they call it. The 14.7:1 is a little too lean for best power for most engines, so the 13.5:1 is a better choice.
