  • SN95 4.6L Mustang Tech
over heating
  • Thread starter Thread starter hudsonj
  • Start date Start date Aug 31, 2006
H
hudsonj
  • Aug 31, 2006
I have an 03 Mach One. It was hit about 2 months ago. I drove it home and then to the repair shop. It is now repaired, but since replacing the damaged parts, it will over heat while driving. Not at idle. You can start it up and it will run without any problems. Only when it is driven will it over heat. The thermostat was changed. Please help!!!
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Aug 31, 2006
  • Aug 31, 2006
did yo make sure that there where no air pockets in the cooling system cause that can cause it too over heat
jeffnoel
1,638
Clovis, CA
Sep 1, 2006
  • Sep 1, 2006
Was the thermostat installed in the right direction?
WAR-PARTY
HURRICANE ALLEY PENSACOLA FL
Sep 1, 2006
  • Sep 1, 2006
Check for water flow, thermostat correct direction and opening If you do that just replace it with a 160 degree stat. ensure that your fan is coming on. the very worst it could be: water pump has gone south or if there are bubbles in the radiator cracked or blown head gasket. Good luck W.P.
the98stang
2,408
Clovis, CA
Sep 1, 2006
  • Sep 1, 2006
Doubt its a HG. Chances are the idiot mechanics left some air in the system. I would check that first and the T-stat
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Sep 1, 2006
  • Sep 1, 2006
The 4.6 DOHC can be hard to bleed if you don't know what you are doing. I would get the system rebled right away..
twogts4us
4,188
12
79
Dunedin, FL
Sep 1, 2006
  • Sep 1, 2006
Idiot at Ford left my wife's fan unplugged. Overheated pretty quickly when the A/C was run. Freakin Jerk-a$$es.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
J
Lack of power on acceleration
  • jameshernandez
  • Aug 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2026
jameshernandez
J
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
