Over Revved in First
  • Thread starter Thread starter No.11
  • Start date Start date Jan 28, 2012
1 of 2 Next Last
No.11
614
10
48
Los Angeles
Jan 28, 2012
  • Jan 28, 2012
The other day I stepped on it, for some reason thinking I was in 2nd gear, and I was standing on it for too long until I felt the car kind of just stop making power and I let go of the gas, I looked at the tach and saw it coming down from way past redline. Afterwards it started making this weird salt shaker noise. It sometimes sounds like 3 shakes at a time, then a second in between, then 3 shakes, a second, and it goes on and on. I ran the codes but could not find anything special. Just code 31 which has been annoying me for quite some time and code 51 which recently returned.
I don't dare take it to wot for fear of really fudging it up. Any ideas? The noise seems to come from somewhere in the vicinity of the bellhousing towards the drivers side, which leads me to believe it might be a bad throwout bearing or the clutch or something. Any help with this is, as always, greatly appreciated!
Edit: Performance hasnt really felt affected as of yet. Then again I haven't really checked. I did drive it for about 20 miles before finally letting it rest though, without anything but that noise bothering me.
No.11
614
10
48
Los Angeles
Jan 28, 2012
  • Jan 28, 2012
here's a video
95Vert383AOD
1,133
34
69
New Bedford, MA
Jan 28, 2012
  • Jan 28, 2012
Personally i would Cross my fingers, remove valve covers and check rockers, push rods and springs....If nothing is bent or broken there then i would pull the motor. Either way you don't want to drive like that.
No.11
614
10
48
Los Angeles
Jan 28, 2012
  • Jan 28, 2012
any other ideas so I don't tear anything off? anything that could be wrong in the vicinity of the bellhousing? that's definitely where the sound is coming from.
although I could use this as an excuse to put in a stroker hehehe...
txstang84
1,639
42
69
Tuscola, tx
Jan 28, 2012
  • Jan 28, 2012
FWIW, the factory tach is known to be slightly inaccurate, and unless you've programmed the computer to ignore the factory 6250 rev limiter you probably didn't actually over-rev it, and the power loss would be the normal running out of cam vs. rpm. It is possible that you tore up your t/o bearing, but you'd probably know that just by driving it...a bad one usually transmits some feedback through the pedal in the form of vibration thumping or grinding. Do you have a mechanix stethoscope? One of the best $8 diagnostic tools one can own...
No.11
614
10
48
Los Angeles
Jan 29, 2012
  • Jan 29, 2012
I wouldnt doubt if it was the TO bearing, as I didn't change it when I had the transmission dropped. But then again I didn't really feel any feedback through the pedal. I'm really hoping it's not an issue with the internals, but if its a blown head gasket or something wrong with the valvetrain I definitely want to take the opportunity to finally get rid of the stock heads. I've had two chances when I had the heads off and didn't upgrade, for lack of money.
Hmmm gonna look into the stetho thingy, does it really help you pinpoint where noise is coming from?
castine917
126
Wyoming, Mi.
Jan 29, 2012
  • Jan 29, 2012
Doctors and mechanics have used them for years to pinpoint problems.
Reactions: txstang84
95Vert383AOD
1,133
34
69
New Bedford, MA
Jan 29, 2012
  • Jan 29, 2012
Usually really high revs have been known to bend push rods. I'm not saying it is but a bent push rod could def. make that sound. I cant talk anymore because i just got back from the bar and the GF is staring at me looking for loving. She gets jealous of stangnet.
Reactions: StangGT1995
txstang84
1,639
42
69
Tuscola, tx
Jan 29, 2012
  • Jan 29, 2012
Ha ha!! Well, I hope you took care of that 'vert! Anyway, he's right, high rpms can bend pushrods, but check everything over with the stethoscope and report back. Just point to where you suspect the noise may be coming from, and listen...vary position as necessary and, obviously, don't touch anything that moves or rotates. As for the head gasket, you can check oil for coolant, coolant for bubbles or fuel vapors, and compression...but, if you spit a gasket, it would probably be running a little "off." If no problems there, then you should be good. I'm with 'vert though...hoping it's something simple.
Here's some other things you can try. Does the noise vary in intensity when you bring the rpms up? If you disco and replace the plug wires one at a time does the noise change or go away? (do be careful performing that one...it can be a very shocking experience)
Blown88GT
2,283
524
164
Palm Beach Gardens, FL
Jan 29, 2012
#10
  • Jan 29, 2012
  • #10
No.11 said:
...The noise seems to come from somewhere in the vicinity of the bellhousing towards the drivers side...
Exhaust pipe hitting the body?
No.11
614
10
48
Los Angeles
Jan 29, 2012
#11
  • Jan 29, 2012
  • #11
I will pick up a stethoscope and try it out and report back. also found that one of my wires was touching the header. must have happened recently because I check my engine bay often and it wasn't touching a day before the little incident.
been wanting to get rid of the ford racing wires...
Rick 91GT
Mustang Master
95
99
PA
Jan 30, 2012
#12
  • Jan 30, 2012
  • #12
Its a weird sound...
Did you rev it, does the sound go increase with the revs?
IF you have a plug wire that hit the header and it is arcing that could be your culprit as it is not firing completly or at all in that cylinder. The Ford Racing wires are junk and have a ton of resistance, go with a set from Taylor.
No.11
614
10
48
Los Angeles
Jan 30, 2012
#13
  • Jan 30, 2012
  • #13
I moved the burnt wire away from the header and the sound seems to be gone. there was a little bit of burning but it didn't penetrate the boot. still, to be safe I'm gonna go with the Taylor wires. would their $29.99 street thunder wires work pretty well or should I be looking at their $80 thundervolt wires for lower resistance than the ford wires?
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Jan 30, 2012
#14
  • Jan 30, 2012
  • #14
I over revved my car one day, throttle spring popped off and snagged onto a vacuum line. Motor was bouncing off the rev limiter for a few seconds, turned the key off. On the side of the road I found the problem, fixed it and drove it home. The next day the car was sputtering like it wasn't on all 8. Popped the valve covers off. Touched every rocker and sure enough broken valve spring. Changed 1 valve spring and all was well. Hopefully yours held up. That high of RPM for awhile can hurt something in milliseconds it seems.
Rick 91GT
Mustang Master
95
99
PA
Jan 30, 2012
#15
  • Jan 30, 2012
  • #15
I prefer the thundervolts
larrym1961
5 Year Member
Dec 18, 2010
570
36
49
Idaho Falls Id
Jan 30, 2012
#16
  • Jan 30, 2012
  • #16
I have had 2 differant sets of those Ford Racing plug wires and that was the problem I had with both of them. They would eventually fall against the header and burn thru. When this happened I opened my hood because of a miss the burned wire caused and I heard a ticking sound similar to the one you were having and that sound I was hearing was the spark arking to the header from the burned thru wire.
Well I won't buy those Ford Racing wires any more just because of that.
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Jan 30, 2012
#17
  • Jan 30, 2012
  • #17
you tried moroso ultra 40's or firecore 50's?
txstang84
1,639
42
69
Tuscola, tx
Jan 30, 2012
#18
  • Jan 30, 2012
  • #18
Sooo, the noise is gone?
No.11
614
10
48
Los Angeles
Jan 30, 2012
#19
  • Jan 30, 2012
  • #19
it seems to be gone. I'm still going to monitor it and replace those wires ASAP. and yes, never again ford racing wires! thundervolts are looking pretty good.
Stever89
5 Year Member
Dec 14, 2009
536
9
39
Biloxi, MS
Jan 30, 2012
#20
  • Jan 30, 2012
  • #20
Another Ford Racing wire failure here, the notorious #5 plug boot caused a very similar sound. I also over-revved mine a while back and posted about it here... I also felt a power loss at the peak like you but I'm pretty sure it was just the valves floating. No damage.
I think you're alright. Other than that sound, the engine/exhaust sounded fine.
1 of 2 Next Last
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
