  • SN95 4.6L Mustang Tech
overheating
  • Thread starter Thread starter white302
  • Start date Start date May 13, 2006
W
white302
42
Whitehouse, OH
May 13, 2006
  • May 13, 2006
i ve search and cannot find any rock solid answers. ok this is a 2000 2v he spun a rod bearing on #4 so we pulled the motor and made the repair. now when we try to warm it up it just overheats like we have a air pocket in the block. any help? we have tried everthing. thanks
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
May 13, 2006
  • May 13, 2006
did you replace thermostat? May be its stuck closed? Waterpump working right? did you bleed the coolant system correctly?
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 14, 2006
  • May 14, 2006
....and if you did replace the thermostate, did you install it the right way? I can't tell you how many times i've seen thermostates installed upside down.
W
white302
42
Whitehouse, OH
May 14, 2006
  • May 14, 2006
yea the thermostat is in ok and is brand new. i filled the block through the thermosatt housing on the intake then proceded to warm it up. still a no go maybe im warming it up wrong or its got a blown headgasket
mity2
Jul 24, 2003
2,872
StateCollege PA
May 14, 2006
  • May 14, 2006
You did purge the air out of cooling system right? Sometimes its hard to get all the air out
W
white302
42
Whitehouse, OH
May 14, 2006
  • May 14, 2006
whats teh best way to purge these cars i warned it up with cap off it just pushes the coolant out to no end
mity2
Jul 24, 2003
2,872
StateCollege PA
May 14, 2006
  • May 14, 2006
Do the search man. there was pretty long thread here little while ago talking about coolant flush
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
May 14, 2006
  • May 14, 2006
the best way is to use a vaccum bleed setup but I doubt you have access to one.
Without access to that you can try to fill it at the degas bottle and rev it slightly, up to about 2k rpm's to aid in breaking up air pockets. Don't worry coolant is going to spill out and overflow from the bottle.
worst case you can pull one of the heater hoses off and fill it there too.
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
A
Resolved 03 GT Parasitic Draw Fuse 26 (PCM)
  • Antrix
  • Mar 22, 2025
SN95 4.6L Mustang Tech Mar 24, 2025
89ripper
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Help! Intake Manifold Gasket or Head Gasket?
  • foxbodyclark
  • Oct 4, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
95 Laser GT Ver
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
