  • SN95 4.6L Mustang Tech
Oxygen Sensor
  • Thread starter Thread starter GOLDENPONY
  • Start date Start date Oct 11, 2004
GOLDENPONY
1,503
LOVELAND, OHIO
Oct 11, 2004
  • Oct 11, 2004
Where are the front O2 sensors located on a 2000 GT? Hard to get to?
tomustang
Psychotic Member
3,434
McLean Hospital
Oct 11, 2004
  • Oct 11, 2004
all O2 sensors are located in the H-pipe, they just screw in, if you look underneith you'll see wires comming from them on the pipes, most are easy to get to
SlapStick1999GT
florida
Oct 11, 2004
  • Oct 11, 2004
On your car there are 4 O2 sensors. the first two are befor the first set of cats if you jack up the car they are right to the sides of the h pipe. Those stay there if you install a after market H or X pipe the ones befor the mufflers are the ones you put the mil eliminators on get the steeda eliminators they require no splicing they just clip up. And on new modles they are a B##ch to get to i got mine off on a lift to get the first two off the second set is simple.
GOLDENPONY
1,503
LOVELAND, OHIO
Oct 12, 2004
  • Oct 12, 2004
O2 Sensor
So if I get the car jacked up I can get to them (front). As I understand, you just usually have to replace the 2 in front of the cats. Car has 76K miles and have a state emissions check comming up. I also want to be sure the engine is running tip top and I am getting the best possible mileage.
T
tazman
9
Dallas Area
Oct 12, 2004
  • Oct 12, 2004
Not Fun
When I installed my new X-pipe I could not get my hand up in there to disconnect the wires for the front two sensors. I had to wate until I lowered the old H-pipe to get to the connectors. The connector on the rear two is the same. Practice on those to see how they disconnect. Find a friend with small hands. Good luck.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
