  • SN95 4.6L Mustang Tech
P0403 Code
  • Thread starter Thread starter One Red Ride
  • Start date Start date Nov 27, 2004
One Red Ride
32
Waymart, PA
Nov 27, 2004
  • Nov 27, 2004
Car ('99 auto GT) has been running rough the last few times I had it out. Don't run it much, so thought maybe it was condensation in the fuel (ran similar when I "washed" the engine bay and soaked the coils). Added some dry gas but no better.
Today I took it out again and it got much worse. Seems like it runs ok until it warms up then runs terrible. Stumbles and bad hesitation when driving. Idles, but like it's got a lumpy cam. So today it's running terrible, but I'm 10 miles from home and the MIL (Service Engine Soon) lights up for the first time. Drive home and pull a P0403 code. Searched this forum with no luck so I did a general Yahoo search and found some threads about F150's with this code being related to a #4 cylinder misfire.
Guess that's question #1: is that what a P0403 means?
Armed with this "knowledge", I decide to change the spark plug on cylinder #4. Not sure, but the plugs may be original factory (46k miles), they were Motorcraft. When I removed the coil (attached to plug) it seemed to have coolant on the spark plug end. Not soaked, but enough to make my stomach turn. I'm figuring cracked head or block... So when I finally get the guts to remove the spark plug all the way, it's not really too wet, the tip was dry. No coolant in the oil pan by inspection of the dipstick. Coolant also looks ok (visual inspection into the fill cap). I'm hoping that it was just a small leak from one of the heater hoses (cylinder #4 is closest to the firewall, passenger side, just under the heater hoses to/from the heater core).
Change the plug (Autolite 754 gapped to .054"), clear the MIL code, and take it for a test spin. Seems to run better and the MIL stays unlit. However, later I restarted the car for another test ride (to be sure and trying to find the coolant leak). This time I let the car warm up pretty well and the hesitation is back. Not terrible, but not fixed either.
Any ideas? I plan to check the coil tomorrow, maybe coolant leak damaged it? Question #2: anyone have a similar experience? Wow this got long, sorry, but I'm a bit frustrated...why just when the car is warm? Any ideas are appreciated.
One Red Ride
32
Waymart, PA
Nov 27, 2004
  • Nov 27, 2004
Bump
  • Gulftown980x
  • Jul 29, 2026
squeak93
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
R
Misfire at high rpm! Help
  • Ryanm2018gt
  • Jan 2, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jan 17, 2026
highplace11
H
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
