Paint Sprayer question (auto paint)
Is this a good spray gun to use for auto painting?
http://www.homedepot.com/webapp/wcs...03+90401+500173&marketID=401&locStoreNum=8125
I have ordered 2 devilbiss sprayers and both times they came messed up. My bday is in a few days and I saw this one at home depot for a bit cheaper (plus I always get home depot gift cards for my bday) and was wondering if you guys think it would do well for spraying my car.
I am going to resurrect my painting my own car thread as soon as I get a damn spray gun so I can start :D
Well, unfortunatley is does not say the size of the nozzle. Some are 0.8 some a 1.0 some a 1.3 and so on. Different types of paint and primer require different tip sizes. Also, see what kind of air pressure is required to run it. My gun requires 30-40psi. A customer of mine has a 600 dollar gun that only requires 15psi, so that thing uses barely any paint.
By the pic it looks to be OK, but you need to find a little bit more info.
I imagine that paint gun is probably made by devilbiss. I used to work for Sears and the Craftsman paint guns were made by devilbiss, they just aren't built to the same standard as the ones marketed as the Devilbiss brand. The Husky tools look to be quite similar as well. It probably would work just fine, you'll just need to find out all of the details like svt32vdohc mentioned above.
Here is what one dude who reviewed it said. I will also go get more info today on it. His air compressor has the same rating as mine too.
"I used this gun to primer my car hood. I sprayed on a 2k Epoxy primer using the guns 1.4mm tip!
Which was great, since i didn't have to buy a 1.8mm tip. Since this gun is gravity feed it needed less material than a regular syphon type gun to do the same job and there was much less "bounce" than there is with my other gun(syphon type).
On one note the cup did seem a little weak, but it was pretty easy 2 cleanup. Even with a full cup, the gun was still amazingly light.
Oh yeah I used this gun with a 2hp 33 gallon air compressor that puts out 8.6CFM @ 40psi, and so the air consumption was barely noticeable, which was great, because my compressor wasnt running all the time.
Pretty much a great gun for the price."
2K Primer is thick and it uses and activator...it is good stuff. 1.3 or 1.4mm tip is a little bit too big for paint, but you could probably use it, just dial down the amount of paint you are using and adjust the fan as well using the knobs on the gun. I think .8 and 1 is for paint and clear. I can't remember. I actually just use 1 tip for everything I spray and my cars always look great....(not being cocky) just being honest.
