so my passenger door wont lock, i can sometimes get it if i turn the key and shove the button down, but its impossible to press it so hard that it locks. i took the doorpanel off and i dont think its getting stuck on anything so could it be the locking mechanism int he door? thanks.
nvrenuff
is your actuator siezed? with your door panel off, does the actuator even try to move when you hit the lock/unlock button, if not, then you may need a new actuator. Check to see if you have power at the plug of the actuator first to eliminate a wiring problem. If all this checks out good, it's gotta be some linkage binding or something. I got my doors all torn apart right now too, (converting to power windows) so if you need me to check something in mine for reference, let me know.
thanks allot, my PDLs work on the driver side, (the side that locks) and it doesent even attempt to do anything on the side that wont. i think it maybe seized up.
I got my last power door lock actuator from O'Reilly Auto Parts, it was made my Motomite "Help". You can order them from most auto parts, 50Resto, and numerous others that you can see in any Mustang magazine. There is also a cheaper fix out there, but you have to fabricate some of the parts.
Buy the actuator, drill out the rivet that holds the old actuator in place, position the new one. I take mine to a local body shop and have them rivit it back into place. Then if you have the $, replace all the panel fasteners with new ones too. I got mine from O'Reilly also. There is a very good tutorial on 50Resto's website. Here is the link http://www.latemodelrestoration.com/download/instructions/LRS-21842.pdf
Here is a picture of the kit that 50Resto has
If you have any more questions, just ask. Good Luck
bubba-dough
jrichker has an awesome write-up on this. I did mine basically the same way as he tells. Plus it is waaaaaay cheaper, like under $20 for both sides. Mine has been done 4 yrs now and not one problem.
FWIW, Motormite is who made the original actuators.
I did the retrofit due to being poor. It works well and takes about an hour or less to do (just an option). Jrichker has the article on his Stangnet website if interested.
I had a plastic mounting bracket for my lock actuators. The plastic mounting bracket has a clip that holds the bracket in place - there was no need to drill the rivet. Had I not broken the plastic mount, there would have been no need to even remove the bracket in the first place. That's just how mine were........in case it saves some time.............
Good luck.
Good luck.
Follow this link to fix your door lock actuator problems http://jrichker.stangnet.com/Mustang_tech/door_actuator_fix/1_of_8_door_actuator.htm
Stuck with door lock actuators that don't work and don't want to pay the $50+ for a new one? Tried the junkyard ones and found that they last six months and freeze up?
A new actuator for less than $4. Fix one side for $17, do both sides for only $23. I don't sell parts, I don’t make any money off of the upgrade, I just tell you how to do it cheaply and easily.
Electrical
Weird door wiring issues
- Replies
- 4
- Views
- 207
- Replies
- 3
- Views
- 315
- Replies
- 3
- Views
- 419
- Replies
- 6
- Views
- 287
- Replies
- 7
- Views
- 542
