  • SN95 4.6L Mustang Tech
Passenger rear sagging 1"
  • Thread starter Thread starter LS2 KLR
  • Start date Start date Dec 19, 2005
LS2 KLR
452
Houston, TX
Dec 19, 2005
  • Dec 19, 2005
I lost a bolt somehow in my passenger side upper control arm a while back and couldn't get an oem replacement bolt. I installed one as close as possible but there was alittle play. It ended up making the hole larger. I had it fixed by having a washer welded in.
Anyway, my passenger rear is sagging an inch or so. I installed a half in spacer to temporarily fix it but my tire somtimes still hits my fender. I don't believe the upper control arm has anything to do with ride heigth but this occured around the same time period. I'm not sure if my frame is tweaked or what else it might be. Anyone....
M
Bent Rear Spring Perches
  • Miozu
  • Aug 18, 2025
SN95 4.6L Mustang Tech Sep 8, 2025
PSKSAM2
P
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
