Interior and Upholstery Passenger Window Won't Go Up Help
Migraine79
my passenger window will let down but will not go up. I've changed switches with no results. I'm losing my ground somehow. I ran a jumper wire and it will go up butt he wire gets really hot. Any ideas??
Yes the ground is screwed into the driver door. I used a test light on the passenger side switch. I am losing the ground going up so I put a jumper wire from the switch to the door and the motor worked
Is it one window or both?
I think you narrowed it down to the wiring.
