  • SN95 4.6L Mustang Tech
Patriot heads ?
  • Thread starter Thread starter 2002BLGT
  • Start date Start date Oct 9, 2007
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Oct 9, 2007
  • Oct 9, 2007
Anybody running these heads with a blower on a stock engine ? if so what kind of cams and what kind of numbers are you putting down ?
D
darkside03gt
851
Sacramento CA
Oct 9, 2007
  • Oct 9, 2007
there is no way in hell a stock engine is gona handle ported head with a blower for very long. unless you were running ported heads with stock cams and around 8lbs of boost on a centri and 6lbs on a KB. keep in mind that the stock engine gets sketchy after 400rwhp. I would pull the engine put some h-beam rods and good forged pistons before even considering a combo like that.
Green&GoldGT
302
Virginia
Oct 9, 2007
  • Oct 9, 2007
I would check out the modular depot section "My ETs" and I'm sure some guys have some numbers. They are actually ported truck heads.
As long as you don't get greedy with pulley swaps, a stock block will be fine. The best way to make power is removing restrictions like heads cams and exhaust and then bring the boost back up to a safe level since those mods will reduce boost. Ported heads will lower compression too. A great and safe tune is a must. Its when people stock everything with a s/c and add boost only that engines give in, or thats just my opinion.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
A
Fuel Capable fuel system for +600hp
  • Avia.tuned
  • Feb 24, 2026
SN95 4.6L Mustang Tech Feb 24, 2026
squeak93
H
1995 cobra engine noise help
  • Holt2010
  • Sunday at 7:07 PM
1996 - 2004 SN95 Mustang -General/Talk- Sunday at 7:07 PM
Holt2010
H
