paxton pulley?
  • Thread starter Thread starter Daniels1414
  • Start date Start date Jul 11, 2004
D
Daniels1414
31
St. Louis
Jul 11, 2004
  • Jul 11, 2004
I have a carburated 289 that I have a paxton for. Stock it will put out about 8lbs of boost. Can I change the pulley to go up in boost and if so where can you purchase the pulleys?
F
Fostang
1,400
Stockton, Ca
Jul 11, 2004
  • Jul 11, 2004
try ebay.
Also that blower is not recomended to exceed a certain amount of rpms.
Which if I remeber correctly with an 8 lb pulley is roughtly 5500 rpm so if you upgrade the pulley it would mean that you couldn't rev the motor up before doing some damage to the blower.
Also recomend getting an oil cooler for it. Change the fluid at least every 1000 miles.
D
Daniels1414
31
St. Louis
Jul 11, 2004
  • Jul 11, 2004
Its oil is supplied from the engine pan. What "fluid" do you suggest changing every 1000miles? Are you talking about the engine oil? I hope not because that would get very expensive.
F
Fostang
1,400
Stockton, Ca
Jul 11, 2004
  • Jul 11, 2004
hmm for some reason I thought you had an SN series blower that is self contained.
66coupe306
32
  • Jul 12, 2004
While I don't remember the exact numbers I had calculated, the 1200 can have a max impeller rpm of about 40-50,000 rpm. There is a calculation to figure out that speed based upon pulley diamters and engine rpm, I'll see if I can find it. The 5500 rpm rating for 8psi is based upon a bone stock 289 which is it's effective usefull rpm. Although I have not used mine yet, I would suspect reving higher than 5500 will yield greater boost. Keep in mind more boost means more heat so an intercooler becomes necesary to keep from retarding the timing too much.
T
Engine Removal of Steeda Underdrive pulley
  • THughes
  • Jun 30, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 4, 2026
Dino Dino Bambino
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
M
Looking for a passenger side AC Compressor mount
  • mustangTodd
  • Feb 10, 2026
Classic Mustang Specific Tech Aug 22, 2026
s_mi11er
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
