Pay Me Now or Pay me Later - Front Suspension ???
mustangdave said:
Pbum5, why do you think your upper control arms are bad? Usually if a car is pulling really hard to one side, it's a bad control valve on the power steering. Do you have p.s.?
I took it into get it aligned and the said the couldnt because
The holes where A arm meets the shaft have oblonged from wear.
They are also almost 40 years old. A little freshen up couldnt hurt.
You need new control arms if the holes where the shaft nuts screw in are oblong and worn out in yours.....there really is no way around it. Check American Pony because they have factory new arms for $69 and you need to specify the 4 rivet ball joint ones also. This is cheap enough to get you back on the road and you can get fancy parts later on when you do a full restore of the car.
65fastback2+2 said:
i dont see how you could do it and NOT have to do that fix. Mine has like 3/4" of shims, theres no getting around that, and my frame was checked against being bent too.... :shrug: :shrug:
So are you saying that EVERY 67/68 that has the Shelby drop done MUST have shims put in to align the front end after the drop?
I am confused because I did the drop and 620 coils and I did not need shims.
I am not trying to start a fight I just want to make sure my car is safe.
Your car is perfectly safe, if it aligned properly then all is well. He also used 1 inch drop springs so maybe that contributed to the need for shims. He is young and assumes that just because his car needed them that all will need them but I do not believe that to be the case because I have never heard others with 67/67 vehicles talk about the need for shims after the Shelby drop. It is almost like his lower control arms are too long. I really do not know what is going on but it was IMPOSSIBLE to align HIS car without the shims.
What kind of spindles are on his car? Couldn't that make the LCA seem to be longer?
He still has the stock drums so that can't be the problem. I always wondered if there were different length lower control arms for different years and if it was possible to get them mixed up.....but I have never confirmed it, there seems to be different part numers so who knows.
Maybe I will take that route for now. Why does it mater if they are 3 or 4 rivets if they are being replaced? Is one better than the other?
I'm just picky and it seems that almost all early cars are the 4 rivet and I just don't like the look of the 3 rivet ones...plus the 4 rivet ones allow you to use negative wedge kits and can even be modified themselves whereas I would not consider it safe with a 3 rivet model so it would give you more options down the road. There is no difference in price so it seems like the logical choice to go with the 4 rivet ones to me.
HistoricMustang said:
Pbum5, sorry for delay in responding.
I have never had an issue with the ball joints - another one of those rumors put out by the big boys to get you to buy stuff to correct things on the other stuff you bought. It is kind of a "Catch 22" situation. Only they are "catching" your money.
HistoricMustang
www.historicmustang.com
What If I do go with the stock type and do a Shelby drop for now. If I later decide to "upgrade" to a modern suspension part (I know many here arent fans of them) will the holes from the Shelby Drop be the same place?
Wow, this thread went all wacky quick... Back to the original question:
Pbum5 said:
What should I do?
... I plan on someday doing a full restoration of my car.... But for now and the next few years or so I would like to make it drivable. When I do decide to do the ground up resto, I plan on going with an upgraded front suspension either from TCP, Maier, or Global West. Here is my question. Should I buy the “upgraded” suspension now, and remove it and put it back when I do the resto, or should I just get a $300 kit to hold me over for a few years and make it safely drivable.
Ok, IMHO, you should try to make a decision about the use of your car for the future. You need a plan. You say you're gonna eventually do a "full restoration" but what does that mean? Do you intend to do a full custom suspension from TCP, Maier, or GW, or just selectively use certain components in combination with some original type components? This will make a huge difference in whether you should do the Shelby drop now or wait. It can also help you save serious money over time.
If you plan to do the a full custom TCP, Maier, or GW suspension, then I'd say do a basic rebuild now with urethane bushings, new control arms, ball joints, tie rod ends, etc. Don't do the Shelby drop yet. You can only drill your shocktowers once and depending on the kit you choose it may be more than the usual Shelby 1" drop. If you want a lower stance and better handling, spend an extra $60 for higher rate lowering springs.
Now, if you plan on doing some combination of stock type components augmented by stuff from TCP, Maier, or GW, then do your research, decide which components you think you'd like to use and then build a good basic suspension from there. If this is your approach, you might like looking at a bit of my ideas about building a suspension, which you can find here: DB's suspension pages .
Hope this helps... :shrug:
yes, i am young and dumb :nonono:
one day i wanna be an old smart fart :D
It's nice to see someone bring this up. I have the same situation on my '70, but I shimmed the ball joints and did a 2" drop. I've been considering fabbing a slightly shorter and adjustable length lower arm to avoid requiring shimming the upper arm. That way I could also do the Boss 302 mod, eliminating the lower arm adjustment point that can move under hard use.
Thanks for the advice. Yeah I do need to make a decision. The problem is that since I haven’t had my car in so long it has been out of sight out of mind. Now that I have it back in my possession after about 12 years in storage I am reading up on things and there are so many options for stuff that was not around 12 years ago. To many choices can make things a bit confusing for someone like me just getting back in the game.
