PCV blown out??
  • Thread starter Thread starter DJorgie76
  • Start date Start date Apr 17, 2005
D
DJorgie76
9
Monroe Township, NJ
Apr 17, 2005
  • Apr 17, 2005
A week or two after I did the mods in my sig, I started to notice an oil leak under the car. It seemed to be coming from the back of the engine. Just this morning I finally got a chance to check it out. I found the PCV valve was blown out of its normal spot and just sitting near the hole. Oil is coming out of the hole and leaking down the engine and transmission. What causes this and what can I do to fix it.
Thanks!!
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Apr 17, 2005
  • Apr 17, 2005
is the rubber gromet that goes into the lower intake ok?
D
DJorgie76
9
Monroe Township, NJ
Apr 17, 2005
  • Apr 17, 2005
it should be, it is was new when I did the work.
gregpro50
140
Binghamton NY
Apr 17, 2005
  • Apr 17, 2005
Did you reuse the stock PCV hose ? I have a Typhoon intake and reused the stock hose and it would end up working its way out too because it was a little longer.
D
DJorgie76
9
Monroe Township, NJ
Apr 17, 2005
  • Apr 17, 2005
I honestly don't remember which hoses I replaced. I plan on replacing it now along with the PCV valve, grommet, and screen. Do you think this will help this?
fords2fast4u
1,426
Mission Viejo, CA
Apr 17, 2005
  • Apr 17, 2005
mine used to blow out on my 95 GTS, due to a pressurised crankcase... i just it blew oil all over the firewall... i got a new one and put some silicone on it.. no problems after that
D
DJorgie76
9
Monroe Township, NJ
Apr 17, 2005
  • Apr 17, 2005
I have oil all over the firewall too. Did you silicone the pcv into the grommet?
KDK1988GT
1,937
Fredericton
Apr 17, 2005
  • Apr 17, 2005
its the crankcase pressure making the oil fly by.. and out the hole.. What I did was place a breather on the valve cover, to release some pressure and I got a Steeda Oil Separator Kit, click link to find out more..
http://www.steeda.ca/catalogue_product_type_918.asp
And like fords2fast4u said.. put some silicone on it (valve, grommet) and that should keep any oil from flying by.
Good Luck
D
DJorgie76
9
Monroe Township, NJ
Apr 17, 2005
  • Apr 17, 2005
I have a breather on the pass side valve cover already. Should I put one on the other side too. I already have another breather.
HISSIN50
34
129
Apr 17, 2005
#10
  • Apr 17, 2005
  • #10
assuming the PCV components fit properly, if someone has that much pressure in the crankcase, i would address that problem rather than welding a grommet in that was never meant to have to withstand that much pressure, as a bandaid.
one might get the grommet to seat but the other seals will be letting oil fly.
i think i must not understand the problem.
good luck.
just4bob50
504
Pa.
Apr 18, 2005
#11
  • Apr 18, 2005
  • #11
I had the same prob. i bought a new grommet at the ford dealer and the tech recommended to put 1 wrap of electrical tape around the out side of the pcv valve and to make sure the hose is of proper lenth. If it come out again ther are other problems. It worked for me.
fords2fast4u
1,426
Mission Viejo, CA
Apr 18, 2005
#12
  • Apr 18, 2005
  • #12
that's right, i remember now, i did put a breather on the valve cover...
cevtv
1,113
Massachusetts
Apr 22, 2005
#13
  • Apr 22, 2005
  • #13
Is it a Motorcraft PCV valve? None of the aftermarket PCV's fit tightly enough in the grommet.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Today at 4:43 AM
manicmechanic007
J
Engine Stalling
  • josh40tay
  • Tuesday at 2:42 PM
Fox 5.0 Mustang Tech Wednesday at 7:18 PM
JD1964
Engine Stock TB - smoke test - leaking bad
  • R82148V
  • May 18, 2025
2K
Fox 5.0 Mustang Tech Jun 5, 2025
R82148V
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
