PCV to manifold
Haus
408
if the PCV valve is supposed to connect to the Manifold. how does it connect. i thought it connected but when i took off my upper manifold the PCV wasnt connected to it. the piece in the picture that i circled was the only thing there. and that was connected in the back. near or in the lower manifold
but what about the other two pieces. there no where to be found on my car.
and where does the screen go.
1992 5.0
there should also be a large grommet that the screen sits below and the PCV valve slides into. Buy a new grommet from the local Ford dealer, it only a few bucks. The screen goes in first, then the grommet, and then the PCV. The PCV is just held in buy the pressure between the grommet and the valve. The other 2 peices arent part of the Fox 5.0
Haus said:
oook i gotcha. so the screen goes below the Gromet and i dont need the F connector. F'in sweet. thanks
Every parts store PCV I have bought has that F connector already installed. I thought they were giving me the wrong PCV, until I realized you just pull that F connector off and you're good to go.
Jeff
