PCV Valve blow by
02_TruBlu
54
Pittsburgh
I searched the threads, and didn't find anything pertaining to newer cars. I am at 50k miles right now and have just experience PCV valve blow by for the second time on this car. The first time was under 30k miles and I replaced the valve at that point. Do I need to keep replacing this thing every ~25k? :( What is causing this happen? My car in not under boost, all I have are UDP's and CAI.
TIA
It is the nature of the beast. It is worse for motors with boost but, NA modular motors do it as well. The easiest solution is an air/oil separator in the PCV line from the PCV valve to the Intake. here is a pic of my installation and another pic of what it trapped just after 60 miles.
In the first picture you can see the line running from the (Motorcraft) PCV valve to the separator which I temporarily mounted to the wiring harness running along the firewall and then the line runs to the intake. It was an easy 10 minute install. I bought the separator at Lowes as well as the 3/8 barbed fittings and the 3/8 fuel line tubing at Autozone. All together I think I spent maybe $20.
Here is a great thread from Modular Depot on separators.
http://www.modulardepot.com/forums/showthread.php?s=&threadid=35895&highlight=steeda+seperator
Thanx alot rjstaaf. Good description and good pics. In my search I read about the seperator, but since it was talked about with the 5.0 guys, didn't know if it was for us too. Looks like I have a new mod coming...
one other thing is aftermarket PCV valves can cause problems, yeah I work at a Ford dealer(selling parts is my job) but we have seen our share of problems wth people using aftermarket anything. IAC, O2's, sparkplugs, PCV valves ect, ect. Ford designs a part to fit wthin certian parameters and the aftermarket widens those parameters to fit mulitply appts, so in the case of a PCV if your using aftermarket, it just might be drawning to much vacuum thru it because of the orifice size. I preach this day-in & day-out about buying aftermarket parts, they may fit like OEM but they don't funcition like OEM parts are designed to.
I posted on this subject a while back and someone replied that steeda also sells a complete kit to take care of the problem..myself ..I will be buying the seperator at wally world and then getting the fittings at a hardware store :)
If you go to Steeda's website and look at the pic, they probably went to Lowes and picked up the parts there as well :D The problem is they want $60 for it when it shouldn't cost anymore than $20 or so. Nice markup huh. :nonono:
Here is a pic from their website.
02_TruBlu said:
Steeda does sell a kit 9646g6 (http://www.steeda.com/PR/Mustang/PR/555-3710.htm) but it is $60 and rjstaaf's looks better.
Thanks for the input Randy, but in my case, I bought the replacement PCV from Ford.
Since I just had blow by, do I need a new one, or can I just clean it up and keep using?
ok, I understand that but did they sell you the right one? I had someone over at Modular Depot that thought ther dealer sold them the right part and as it turns-out they got one for a DOHC and the have a SOHC Gt.
Wikkdgt said:
Can someone explain how you know if you have blow by from your PCV Valve? thanks.
a smokey exhuast every now and then and using 1/2 a quart of oil between changes even tho the mototr is in great shape..its becuase the valve sucks so hard under throttle it suck oil form the valve cover with it..VERY common
Randy: Yes I am sure. I looked up the number myself before hand and then checked it with what the dealer showed. It took a week to get it as they had the DOHC ones but none for GT's.
"a smokey exhuast every now and then" & "oil in the throttle body"
Hmmm.. you two got me worried now. I have oil on my valve cover and some got on the header. That's how I knew, I could smell it while driving. The first time it happened, smoke came up from the hood and then a cloud when I opened the hood. Almost started crying as I thought I blew the motor or something.
or pull the hose off ans check for oil. i didnt have any in the TB or plenum, but i did have it inside the hoses. knowing lowes sells the seperator, i'll get it done this weekend with my clutch cable, quad, shift handle, and FW adjuster.
Torinalth
Torinalth
Another good point there also...How much do they run at lowes anyway? You can get a nice shiny blue one at wally world for under 12 bux..jsut not sure exactly what the fittings will cost..
