pcv valve replacement...
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
hey
after taking my lower intake manifold off i noticed that where the pcv valve goes nothing is there, its just a wire mesh screen, so i went to the auto parts store and bought a new pcv valve but it doesnt fit in right, the diameter of the the pac valve is too small for the hole on the manifold where the screen is, which made me wonder if maybe there is a little rubber fitting that slides over it or something so it can fit in the larger diameter hole on the intake manifold..does anyone know where i can get one of these or what im talking about?
There is supposed to be a rubber grommet in the hole. Wire mesh on the bottom, PCV on top. Not sure, but the local parts store should have it. The wire mesh is supposed to be replaced periodically also, but it can be a pain to get out sometimes.
ok hey thanks guys, i appreciate, ill get one of those grommets and wire meshes asap. So the pcv valve hose connects to the back side of the upper intake??? Is there something i can look for back there?
by the way what does the pcv valve do?
Yeah...if you look from the drivers side fender underneath the upper intake there should be a "two-way" fitting screwed into the bottom of your upper intake...the open end facing the firewall is where the pcv hose connects to the pcv valve...and the other open end (facing the radiator) makes a curve with the hose up to the front of the upper intake...I hope that made sense...I think you will see it once you get that new hose...
Good Luck
deftsound said:
and i suppose not having one could effect the idle of the engine and gas mileage?
Well I'm sure the loss of crankcase pressure (that mesh filter is probably making it act like a vacuum leak)...that it would effect the above things...like the idle and efficiency of the air/gas mixture being burned...
go get the stuff from your local ford dealer,it'll fit much better than the parts store ones anyway.i tried a purolator one and it wouldn't stay in even with a new grommet and screen.i installed a motorcraft one and it fit like a glove.
If your talking about the little elbow (looks like an "F")...I believe you just rubber cap it off on the top one?
Mine don't have it...I just have one hose to the pcv valve...
i did not read this whole thing - if you have an aftermarket valve with two fittings (normally at a 90 angle from the valve), you can break that off to reveal one male fitting which should hook right up to your existing hose. the aftermarket valves are made to fit a bunch of applications, hence the extra fittings.
good luck.
I know my motorcraft pcv valve came with that "f-fitting"...going to change it out when I redo the valves and put new valve covers on...but I'm just going to trash it because my car didn't have one on it to begin with...
