PCV valve ?'s
  • Thread starter Thread starter bentley429
  • Start date Start date Sep 6, 2005
bentley429
Banned
Nov 25, 2004
528
Connecticut
Sep 6, 2005
  • Sep 6, 2005
Well I just took my old one off and it is a straight valve and the new one they gave me was shaped like a "F". I I hooked the 3/8 hose up and started the car and from the other line on the valve it started blowing out air. There was a random hose that I saw that matched perfectly with it and I put it on and it stopped. Should there only be one hose on if so how do I stop the leak? Thanks
legalize420
1,541
South Florida
Sep 6, 2005
  • Sep 6, 2005
i dont have a fox so my vacuum lines are a little bit different but i doubt having a random hose laying around can be any good. i went to the parts store and told them what kinda car i had and they tried giving me the F shaped one and since i had seen mine before that i did not buy it. im sure you can make it work by pluging the hole that was leaking but the pcv valve i ended up getting was the inline motorcraft one from 50resto. its only a couple bux.
R
rowdie- stang
172
augusta ga
Sep 6, 2005
  • Sep 6, 2005
You got the wrong valve man...take it back
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Sep 6, 2005
  • Sep 6, 2005
Buy a Motorcraft one, that "F" is set to fit on a different Ford Vehicle. You MIGHT be able to just remove that "F" section and then it will be straight like the one you removed.
legalize420
1,541
South Florida
Sep 6, 2005
  • Sep 6, 2005
try that, because now that i think about it, in the box with my motorcraft pcv there was that F piece in there also just not attached.
spyne
78
Fairfax, VA
Sep 6, 2005
  • Sep 6, 2005
Just pull the F part off the top of the PCV Valve. All of the Motorcraft PCV's I bought came this way.
HISSIN50
34
129
Sep 6, 2005
  • Sep 6, 2005
Yeppers! The 94-95's use that F- connector, and other 5.0L powered cars use both nipples - hence their being there. The last Motorcraft valve I bought had the F part separate in the box. Otherwise, for a fox just break the F off (like Spyne said).
Good luck.
legalize420
1,541
South Florida
Sep 6, 2005
  • Sep 6, 2005
are you sure about that because the one i pulled off of my 95 did not have the F? if so someone must have changed mine out and did something to the vac lines before i had the car. i only have one 3/8 line going to my pcv.
vristang
4,933
101
124
Seattle
Sep 6, 2005
  • Sep 6, 2005
All of the F pcvs I have bought have had a small plug for the small outlet. You should be able to plug the small hole and only use the large one. If not just break off the plastic F fitting like everyone else suggested. It may also depend on how it is easiest to route the pcv hose to the intake.
As far as the random line, you need to find out what that was. Worst case scenario is it is the source of a vac leak, best case is it is the supply to something that didn't work before (climate control or cruise control). Either way you will be happier if you find out where it goes. Let us know if you find out what it is/where it routes to.
Something else to consider is that air was blowing out of the extra fitting on the pcv. This suggests that you have more blowby than vac. It may be a good idea to perform a compression and/or leakdown tests. Might be worth worrying about, and might not.
best of luck
jason
HISSIN50
34
129
Sep 6, 2005
#10
  • Sep 6, 2005
  • #10
yep - I am sure. the stock molded hose bends in from the side - not from the top (as you know, there is about no room to have an OEM hose come in from the top - you can, but it is easier from the side, hence the 90* F-connector).
Jason is right - the valve should have come with a little vac plug. that does go on the little port. 3/8" line is correct for the PCV hose.
FWIW, in stock form, the line leaves the PCV valve and goes to the driver side rear of the plenum. It hits a Tee there. That molded hose is about 6-8" long.
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
