  • 1994 - 1995 Specific Tech
PCV Valve?
  • Thread starter Thread starter GTA_V6_Mustang
  • Start date Start date Nov 30, 2006
GTA_V6_Mustang
1,326
Miami, FL
Nov 30, 2006
  • Nov 30, 2006
Ok according to the autoparts store (Which i know are not always right) I have a PCV valve on my car. Well I am looking and dont see one? Do I really have one and if so where is it?
Stanger007
2,015
Baton Rouge, LA
Nov 30, 2006
  • Nov 30, 2006
It's hiding behind the intake manifold - you can see it if you look from the passenger side - right between the lower intake and the firewall.
T
tjh566
608
Northern Va
Nov 30, 2006
  • Nov 30, 2006
yup as said above, it goes into the lower intake, right in the center of the rear of the intake, hard to see...
HISSIN50
34
129
Nov 30, 2006
  • Nov 30, 2006
You might need to push a wiring harness longitudinally to see the PCV valve. As said, it's pretty buried.
I'd get a Motorcraft valve, screen and grommet. Aftermarket valves often dont fit real tight, and grommets get old and vulcanized. And the screen gets clogged. Replace them all with Motorcraft stuff and forget about it for a couple years.
Good luck.
GTA_V6_Mustang
1,326
Miami, FL
Nov 30, 2006
  • Nov 30, 2006
screen??? And yea I will probably go with some motorcraft stuff.
HISSIN50
34
129
Nov 30, 2006
  • Nov 30, 2006
The parts store probably calls the screen a breather filter. First you pop the PCV valve off. Then the grommet comes off (it might come off with the PCV valve too). Then underneath both there's a screen buried. It's the last line of defense for knocking down oil before it goes through the PCV valve. And as such, it tends to get pretty clogged up. WHen it clogs, as Prokiller indicated, that entire leg of the PCV system starts to bog. The little line from the CAI to the oil fill neck tries to help out but it's not enough. Then the pressure starts finding another outlet.
A
Al J
307
North Providence, RI
Dec 2, 2006
  • Dec 2, 2006
Excellent Advice---do this.
Also, you might want to add an oil trap for extra insurance.
Steeda sells 'em or you can make your own.
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
M
Idel control valve
  • miser143
  • Oct 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
General karthief
R
Fox Hydroboost conversion/proportional valve
  • RubyRedNotch
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
RubyRedNotch
R
