People who have changed their shocks
[Twitch]
168
Montreal
People with aftermarket shocks
I have a question. On a stock 2001 GT, when you remove the front shock, there is a metal spacer on top of the dust boot.
Now here's my question, do I reuse that metal spacer when I'm putting new aftermarket front shock? No C/C plates BTW.
My suspension kit that I put in is the Ford Racing M-5400-A
OUR01GT said:
What shocks/struts did you end up getting since I last posted about my setup Kilgore?
Yeah, I meant STRUT on the front sorry... I changed the shocks and struts last summer. I put in Gabriel SVTs that I got at AutoZone for ~$100 for two shocks and two struts.
The stockers were absolute crap but I could not afford the Bullitt kit so I went with the Gabriels. They are holding up well I think...
Kilgore Trout said:
No spacer... I do remember that the Haynes manual said to not re-use the top nut on the struts. The new ones came with a new nut so I used the new one...
Yes, do use the new nut. If I remember right from the rod up, it should go in this order:
Bump stop
Steel plate
Rubber bushing
Metal washer
Nut
This is on the struts. :nice:
when you remove the strut, just have the new one next to it, remove the nut fron the old one, take off EVERYTHING that is not part of the strut, and then slide it over the new one.... saves on headaches :P
Torinalth
