????Perfect carb for a 289????
  • Thread starter Thread starter Garrettn
  • Start date Start date Apr 28, 2004
G
Garrettn
10
  • Apr 28, 2004
I'm almost 16 and love power. ive been loooking for parts to spruce up my 289 to make it a lean mean chevy-killing machine while i wait for my stupid budget to go up. id like to know what size of a carb i need. What brand is the best for the buck, Holley? I have basicly a stock 289. you can tell it has an agressive cam and headers. Also what manifold would work best should i make the switch over to a 4barrel?
Garrettn
D
D.Hearne
11,730
south louisiana
Apr 29, 2004
  • Apr 29, 2004
If you want bang for the buck, you can't beat a Holley list # 4412 500 cfm 2 bbl. It's a direct bolt on swap to your 289's 2 bbl intake. Only mod involved is a slight rerouting of the fuel line. If you decide to go with a 4 bbl , then the Ford Racing A321, older C9OX , Edelbrocks older F4B are good ones, along with a Performer RPM or Weiand Stealth.
O
Ozsum67
Too much thin air
5,152
Eastern Colorado
Apr 29, 2004
  • Apr 29, 2004
Loud headers don't make for an "aggresive" cam. I would think that IF there was a "stock" aggresive cam in it, someone would have put in an aftermarket carb. The problem is having too much carb, if your engine doesn't have the guts to handle it. If it doesn't, you get black spark plugs.
Edbert
3,548
32
109
Austin TX
Apr 29, 2004
  • Apr 29, 2004
The stock carbs work great on stock motors, getting an aftermarket might improve your power but only VERY slightly on a stock motor, and most likely at a cost of efficiency. I'd put headers and dual exhaust on it before I do a carb swap.
If you really want more power then put a new cam in it and grind out the outer inch of the intake and ehaust ports on each head to match the gaskets...THEN get a new carb.
allcarfan
The Answer Man
2,458
North Atlanta
Apr 29, 2004
  • Apr 29, 2004
If you need an intake...let me know, I have three of them...2 edelbrocks, and a weiand xcellerator.
Carb suggestion bang for your buck....edelbrock 1405 or 1406....off ebay.
67stangvert
177
Chicago, Illinois
Apr 29, 2004
  • Apr 29, 2004
Go stock
Id go with a 4V Autolite 4100. Very reliable.
A
akd67
Banned
Apr 6, 2003
231
Small Town Illinois
Apr 29, 2004
  • Apr 29, 2004
D.Hearne said:
If you want bang for the buck, you can't beat a Holley list # 4412 500 cfm 2 bbl. It's a direct bolt on swap to your 289's 2 bbl intake. Only mod involved is a slight rerouting of the fuel line. .
Thats good "$ saver" advice.
Rent-A-Racer
187
  • Apr 29, 2004
allcar, I may be interested in an Edelbrock intake for the right $$. Send pic and price if you don't mind!! TIA
D
D.Hearne
11,730
south louisiana
Apr 29, 2004
  • Apr 29, 2004
Yea, don't I know, I've had two of them in the last 30 years. Had em on 4-5 different motors. Worked great on all of them. From a bone stock 302 in a 69 Econoline van, to the center carb on a three duece 390. The first was bought when I was Garrettn's age, and for the same reason, most economical way to get 4 bbl performance without buying and swapping BOTH an intake and carb.
G
Garrettn
10
#10
  • Apr 30, 2004
  • #10
thanks for the advice
R
1974 Datsun 620 pickup / 5.0L HO
  • RJH46
  • Aug 24, 2025
  • Other Auto Tech
Other Auto Tech Aug 24, 2025
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
J
66 ….289 heads
  • johnMaclean75
  • Feb 9, 2023
1965 - 1973 Classic Mustangs -General/Talk- Feb 11, 2023
2Blue2
