performance mods
  • Thread starter Thread starter jlangholzj
  • Start date Start date Jul 27, 2008
jlangholzj
Mustang Master
Oct 23, 2006
248
31
93
MI
Jul 27, 2008
  • Jul 27, 2008
well....not quite
I'm thinking of adding a spacer between the 600 holley and the eddelbrock RPM intake.
my question is, what size should i put in, 1", 2" etc. I'll take a look today and see what kind of clearance I have.
thanks
john
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Jul 27, 2008
  • Jul 27, 2008
I'd just go with the 1/2" spacer for heat seperation. You may gain 1 or 2 HP with a larger spacer, but it'll hurt you on the low end.
bnickel
5,640
lubbock, texas
Jul 27, 2008
  • Jul 27, 2008
i agree, just some kind of short phenolic spacer and that's it
jlangholzj
Mustang Master
Oct 23, 2006
248
31
93
MI
Jul 27, 2008
  • Jul 27, 2008
i heard that it was supposed to extend the powerband....much like a highrise. but was i just fed a bunce of BS?
rbohm
6,698
550
204
tucson,az
Jul 27, 2008
  • Jul 27, 2008
the thing about spacers is they can add power, if you get the right one for your engine. i have seen 4 hole spacers add high rpm power, and i have seen open spacers add low end power. how much? about 3-5hp at best on most engines. like bnickle said use a 1/2" thick phenolic spacer to insulate the carb from the intake.
jlangholzj
Mustang Master
Oct 23, 2006
248
31
93
MI
Jul 27, 2008
  • Jul 27, 2008
this might help with my issue when the car gets warmer too....
calpolymustang
217
Santa Rosa, CA
Jul 29, 2008
  • Jul 29, 2008
I have yet to see a phenolic version, but I've always liked this style spacer:
zookeeper
3,415
63
109
Rogue River, Oregon
Jul 29, 2008
  • Jul 29, 2008
I used to have a "spacer" like that on a past hot rod. Not a great street manifold, but it sure looked great.
BornInAFord
199
Bend, OR 97701
Jul 29, 2008
  • Jul 29, 2008
You can get a 1/2" spacer like the ones from Summit to fit for sure. I'm not sure about an inch one. When I was running a Stealth (which is slightly lower than the RPM), I could use a 1" spacer under the hood of my 66, but had to cut a little off the air cleaner stud and use a flat wing-nut. Currently my Torker 289 has a 1"spacer, too, but I had to use a 1/2" drop bracket for my RMP motor mounts to clear the hood.
Spacers are used as a tuning aid and can bump up or down the useable range. I normally think of 4 hole spacers as for improving the low end and open spacers as for the top end. The reason is that the 4 hole increases air velocity through the venturis and improves carburetor signal and airflow direction (most carburetor's throttle plates aim the air towards the back of the engine, so even a small extension below the plates helps to straighten out flow. The open spacer helps in upper RPMS by increasing plenum volume, by allowing a more gentle curve for the air flow to follow into the ports and by increasing the sharing of all 4 barrels for the whole engine (the RPM already has a cutout at the top of the divider for this purpose, so you just add to this). Different camshafts and carburetor/head/exhaust combos can change the engine dynamics quite a bit, so what works (open vs 4 hole and 1/2" vs 1" vs 2") for one engine may have quite a different effect on another. That's why what I just said is different (but often just as true) from what was stated by previous posters.
Spacers are a cheap and easy to install tuning aid (~$30 at Summit), so you can play around with a few and see what each does... Just clay the air cleaner (or use wadded aluminum foil) to see if you have clearance before you shut the hood.
Daniel
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
