Phone pictures
Not a fan of the rear louver without Mach wheels... I dunno what it is about Bullits and not going well with the rear louver, but it's the reason I didn't.
I can't tell 100% from the pics, but I think I dig the 1/4 window delete, even without the fancy "normal" scoop style.
More pictures
Still using same phone.
SLP Long tubeheaders,Subframe connectors,13" brakes all around,SLP Line lock,275/40/17 Kumos, 17x9 Black chrome rims,Modified seat extender driver side,Leather interior,5% window tint,75mm throttle body, C&L plenum, Stage 2 1/2 MPH heads, Stage 2 cams, Under drive pulleys, Steeda front & rear sway bars, X2 Ball joints, UPR Bump steer kit, Welded axel tubes, 4 3/4" End links, UPR Lower control arms, Welded torque boxes, Aluminum drive shaft, Hurst short throw shifter, 10000 HID Head lights, HD Blistins shock & strut, H&R Supersport springs,Summitt caster & camber plates, Poly bushings on front sway bar, Rear Louver, Blue interior dome light, 300rwh, 315rwt
