  • SN95 4.6L Mustang Tech
PI Cams and Intake
  • Thread starter Thread starter 96modularGT
  • Start date Start date Jan 17, 2008
96modularGT
  • Jan 17, 2008
I want to install PI cams and intake on my stock romeo heads. I have heard that you can keep the timing set with an anderson tool and remove just the cams with newer romeo pi cams and slide the cam gear back on. Have any of you guys done this, and how hard will it be? I just dont have the money to spend on the whole PI conversion.
Thanks,
Adam
CobraRed_96_GT
1,421
UCSD/La Jolla
Jan 17, 2008
  • Jan 17, 2008
romeo gears bolts back onto the cam - but yes this is possible
d98gt
4,505
59
204
SE Texas
Jan 17, 2008
  • Jan 17, 2008
There are a quite a few writeups with plenty of pictures. Just do a basic search and you'll find it.
SN95forums.com has one aswell.
96modularGT
  • Jan 17, 2008
ok,
Thanks
M
Mel96GT
255
San Diego
Jan 18, 2008
  • Jan 18, 2008
This is a simple install IF you use and Anderson tool or the Ford tool to change cams. I did it and it was simple, but I took my time and re-checked and torqued everything. This is a very cheap mod and worth the effort.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jan 18, 2008
  • Jan 18, 2008
Make sure you read everything you can. The intake swap and cams can be done independently of each other without too much overlap of work.
A suggestion? DO the intake swap first and if all is well then tackle the cam swaps. That way if you have issues you can troubleshoot without too many issues with the combined work. You can also decide after the intake swap if you have the ability to tackle the cams as the level of difficulty increases a bit.
BlackGT4.6
103
In.
Jan 18, 2008
  • Jan 18, 2008
I did it without the tool most people say the tool is a pos anyways. Just take your time it isn't a quick and simple job but it is far from impossible if you half way know your way around a wrench.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
9
Will I feel a difference
  • 90Stanger302
  • Mar 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 13, 2026
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
