If you have a 98 or earlier look at the intake manifold. If it takes up all of the valley between the heads then you likely have PI heads unless it was just a PI intake swap. The NPI intake you can house a family of cats under it. Otherwise all 99+ Stangs are PI heads.
the car is a 2000 gt but i just had a third motor installed from a wrecked 03 gt i just wanted to make sure the mechanic didnt shat me because with an off road h with a 75mm throttle body intake plenum with a cai, this thing is suppose to make a mean sound
tthe car is a 2000 gt but i just had a third motor installed from a wrecked 03 gt i just wanted to make sure the mechanic didnt shat me because with an off road h with a 75mm throttle body intake plenum with a cai, this thing is suppose to make a mean sound
Do what was suggested above. If you have to, take a pic of the intake if your not sure. Basically if you can see below it and there is a TON of room, then its a pi intake. Which is a start but no guarantee.
