since ive owned the car, the right taillight has always been foggy, i think they replaced the left one sometime before i bought the car. Any ideas on what i may do to clean that up, amke it shiney?
can't make it worse.
go.rei GT said:I had the same problem except my left one was bad. I used some 3M polish I have (not the plastic one) and it worked great! When I was done I ended up using it on the good one too, because my left one made the right look slightly faded. If you have any polish, just try itcan't make it worse.
SuperDust22 said:where did you get the 3M polish?
Dustin
94GTLaserRC said:800 is ok...I usually say 1000 b/c the 800 is not so easy to find, and you cant stress enough that there are variable ways to achieve the same results.
RC
Well that's where I work, so I get it there, but you have to go to the auto section, NOT hardware.go.rei GT said:Funny you should say that, I got my 800 at Wal Mart.![]()
Very true though.
94GTLaserRC said:DONT Spray paint on there..
There are a lot of us that have done the following:
WET sand with 1000 grit or so. Then use polishing compound..and buff the h3ll out of it. that will "redden" them up really nice.
RC
