Picture of stripped speedo gear
Mine looked like that too...
As far as I know, all the speedo gears for the non-stock final drives don't "fit" perfectly. Just depends how lucky you are as to how long they will last. I got another, from a Jeep dealership, and sanded down the knurls slightly. That helped. The second one has lasted a lot longer.
You bought one from a Jeep dealership? Do Jeep speedo gears work? Are they better?
I just pulled my 23 tooth gear and it looked as bad after 3000 miles, freaked me out but I put it back in and it works fine.
If it stops working then I'm going to file the new one down some in the hopes that it lasts longer-the above post sounds like it will.
FYI- when I went the jeep delaer and asked for the 23 tooth gear with the part number parts guy told me its not stocked anymore-anywhere so I got it from a mustang parts place.
Same thing they told me at first. The part number is an older Jeep part number however, they crossed it and it is still available. I picked mine up yesterday. They also said they can get more but they will have to order it. It just requires the part counter to do a little extra work.:nice:
