  • 1994 - 1995 Specific Tech
PING PING PING!
  • Thread starter Thread starter rich1223
  • Start date Start date Aug 5, 2004
R
rich1223
69
NYC
Aug 5, 2004
  • Aug 5, 2004
Ok this i really getting fustrating!Iam really having a hard time with this pinging nonsense!I have changed the MAF sensor,ACT,ECT sensor,balancer,Kirban FPR,Distributor,IAC valve and still no luck it still pings at 3/4 or full throttle and when the weather is hot and humid it's worse!And if the A/C is on forget it!Now is it worth it to change the oxygen sensors or will it be another wate of time and money?I have had many stangs before,85,87,88 notch,89 and 90 and have never had this problem!thanx
HISSIN50
34
129
Aug 5, 2004
  • Aug 5, 2004
how is the FP at 3/4 throttle? how hot is the motor running (based on stock gauge or aftermarket gauge)?
codes?
good luck.
TSWG00
202
Snohomish, WA
Aug 5, 2004
  • Aug 5, 2004
LOL I had the same problem but never changed any of the MAF or anything like that just got an off-Road H-pipe and never had the problem either that or I can't hear it over the Pro Dumps LOL. Although I have noticed that my gas millage has gone down probably cuz I hold it wide open all the time now LOL. What I love to do is get up next to someone down a hill or under an over pass turn the car off down shift from 4th to 2nd and cost a little bit then turn it back on and KABOOM scared the crap out of people hehe. I know I"m evil LOL
R
rich1223
69
NYC
Aug 5, 2004
  • Aug 5, 2004
My fuel is set to 40 psi with the vacum off.Never checked it at 3/4 throttle but sounds like a good idea.The car doesn't run too hot the stock gauge reads at about O mark goes up to M or a little past then the fan kicks on.But who knows even though i changed the sending unit it still might not be too accurate.I might just go and try the 02 sensors.I tried everything else why stop now!
HISSIN50
34
129
Aug 5, 2004
  • Aug 5, 2004
ah, i forgot the easy one. what is your timing? seems like the SN's have more ping issues and have to be careful of base timing settings.
JJ95GTID
1,141
Phoenix, AZ
Aug 5, 2004
  • Aug 5, 2004
Timing is important. Also, what octane of fuel are you running? In the summer I would run 91-93 octane with no more than 12* of timing. You may have a ton of carbon build-up on the pistons and combustion chambers. So, you might want to go event lower timing. Say 8-10* and run the higher octane till cooler weather comes.
MLC Stang
210
Atlanta, GA
Aug 5, 2004
  • Aug 5, 2004
rich1223,
Here's one more thing to add to your check list. An EGR system that is not functioning correctly is a definite candidate for causing PINGING problems!
When exhaust gases are re-circulated into the combustion chambers, they SLOW the burn rate since they are inert gases. This means that the computer has to INCREASE spark timing so that the fuel/air/EGR gas mixture completes burning at the proper time for optimum power. According to industry articles that I’ve read the computer will advance the timing about 2 degrees for each 1% of EGR flow, up to a total of 20 degrees of additional advance at 10% EGR flow! So, if your system is NOT re-circulating the correct amount of EGR gases and the computer still advances the timing… you’re gonna ping for sure!
Same thing will happen if your EGR system is sucking in outside air from anywhere that it shouldn’t, e.g. a leaking EGR valve to intake manifold gasket or a leak in the exhaust header to EGR valve transfer tube. Air burns! EGR gases don’t. The extra air is gonna cause pinging if the computer thinks that it’s all EGR gases and advances the timing.
Good luck, and let us know if you get it solved.
R
rich1223
69
NYC
Aug 5, 2004
  • Aug 5, 2004
I run nothing less than 93 octane all year round and my timing is set to 10 degrees (stock)setting but i guess i'll check it again to be sure.Ok i guess it's also time to check EGR system.What can be done about carbon build up!Is there anyway to get that junk cleaned out?maybe spray some throttle body cleaner into the intake?thanx
gcomfx.com
3,690
Republic, MO
Aug 5, 2004
  • Aug 5, 2004
What are your plugs gapped at? I used to have problems on the juice, but gapping the plugs a little tighter helped a lot. Now I can predict my ping based on my fuel pressure setting.
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
  • dan50
  • Jul 18, 2026
dan50
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
