  • SN95 4.6L Mustang Tech
Pinging, adjust timing or add fuel?
  • Thread starter Thread starter Twisted
  • Start date Start date Sep 17, 2007
Twisted
387
Hansen,CT
Sep 17, 2007
  • Sep 17, 2007
I noticed some slight pinging at WOT from ~3500 and up. I have a diablo predator and am running the 91 octane tune. The car only gets 91-93 octane. I understand the pinging is the fuel igniting before it should by the heat/pressure in the cylinder. My question is should I advance or retard the timing? Would adding fuel help?
Stan Weiss
347
Philadelphia, PA
Sep 17, 2007
  • Sep 17, 2007
What is your A/F ratio. If it is lean adding fuel will help. Does it do this on 91 and 93 octane or just 91?
mogs01gt
3,113
30
119
Ohio
Sep 17, 2007
  • Sep 17, 2007
Whats the timing set to?
Twisted
387
Hansen,CT
Sep 17, 2007
  • Sep 17, 2007
Using the data log feature of the diablo looks like base tune is 14. At +5500 I see numbers as high as 41.
Twisted
387
Hansen,CT
Sep 17, 2007
  • Sep 17, 2007
I noticed it autocrossing Saturday and was on 91. I filled up with 93 on the way home and will test it out in a little while. A/F is unknown, running the diablo tune unchanged.
Twisted
387
Hansen,CT
Sep 17, 2007
  • Sep 17, 2007
Did some WOT runs today on 93 octane. Seems to be better. I cannot always find 93 octane though, so what would be the safest thing to adjust, fuel or timing?
san~man
O-G
A little grass shack on a big lava rock
Sep 17, 2007
  • Sep 17, 2007
Well, if you can't always run 93, then the obvious thing is to retard timing.
T
thomas91169
I'd donkey punch my sister.
Aug 19, 2005
Modesto, CA
Sep 17, 2007
  • Sep 17, 2007
either or. it really doesnt matter how you do it, I would add fuel before backing down timing, but thats just me. if im getting detonation/knock i will try to add fuel in small increments, if that doesnt work, then i will pull timing. once i get to the point of no knock/predetonation, i will try to take some of the fuel away that i added and see what happens. of course, tuning a mustang is a little different than a dsm.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Sep 17, 2007
  • Sep 17, 2007
first off is it the generic tune that you have or did you modify it a bit ..... like add more timing.......... you should add about 5% more fuel....
on my tune i have the timing maxed out with the fuel set at 23% more richer on both ends to give me a 13.7 A/F ratio WOT
C
comporange04GT
110
#10
  • Sep 17, 2007
  • #10
03ghoststang said:
on my tune i have the timing maxed out with the fuel set at 23% more richer on both ends to give me a 13.7 A/F ratio @WOT
I don't mean to hi-jack this thread but what is a safe A/F ratio to run at WOT. My tune has the A/F between 12.6 and 12.9 at WOT and I think that is a little on the rich side for an NA motor but I have been told it is on the lean side.
Twisted
387
Hansen,CT
Sep 18, 2007
#11
  • Sep 18, 2007
  • #11
It is an unchanged Diablo Performance Tune. I'll add a little fuel at a time and see if that helps.
mogs01gt
3,113
30
119
Ohio
Sep 18, 2007
#12
  • Sep 18, 2007
  • #12
What fuel did you fill up with when you started to ping?
Twisted
387
Hansen,CT
Sep 18, 2007
#13
  • Sep 18, 2007
  • #13
91. That is what the tune was for. On 93 it seems better, but I cannot always find 93. I just want to adjust the 91 tune to get ride of the ping.
mogs01gt
3,113
30
119
Ohio
Sep 18, 2007
#14
  • Sep 18, 2007
  • #14
I meant what company. Please tell me it wasnt BP or Speedway.....
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Sep 18, 2007
#15
  • Sep 18, 2007
  • #15
for a N/A lighty modified motor (i.e, CAI, TB, plenum, just your basics) an 13.0-13.7 will be good now if you have cams head work and other little things then 12.0-13.5 would be a bit more on where it should be
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Sep 18, 2007
#16
  • Sep 18, 2007
  • #16
ok just keep adding fuel till it goes away but dont just add in big increments add like 2% at a time
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Sep 18, 2007
#17
  • Sep 18, 2007
  • #17
to make a proper correction, you need to know the a/f ratio. if there is too much timing, dumping more 91 octane in to fatten the a/f ratio isn't going to fix the problem.
Twisted
387
Hansen,CT
Sep 19, 2007
#18
  • Sep 19, 2007
  • #18
I only go to mobil or sunoco.
mogs01gt
3,113
30
119
Ohio
Sep 20, 2007
#19
  • Sep 20, 2007
  • #19
Then it sounds like you need to drop the timing back to 13 degrees or go get on a dyno and see what your a/f ratio is.
BurningRubber
1,865
24
58
Sep 20, 2007
#20
  • Sep 20, 2007
  • #20
Mine pinged when I advanced it 5 degrees, backed it down 2 degrees and all is well, at least to my ears.
  • Gulftown980x
  • Jul 29, 2026
squeak93
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
  • dan50
  • Jul 18, 2026
dan50
