pinion head thickness
  • Thread starter Thread starter rockyracoon
  • Start date Start date Aug 9, 2010
R
rockyracoon
874
27
49
margate NJ
Aug 9, 2010
  • Aug 9, 2010
my original 327 pinion had a thickness of 1.874
the new (410) FRPP pinion head has a thickness of 1.895.
so since the new pinion head is .021 thicker, would it be logical to assume that the correct pinion shim would have to be somewhat thinner than the shim on the factory(327) ?,thats what the MHD method would conclude,however in my mind even though the 410 pinion head is thicker than the 327 head,the 410 pinion is definetly smaller in circumference,so I cant see how the MHD would lead towards the correct shim. to me the circumference has to make a difference in some way.
__________________
347HO
462
Seattle
Aug 9, 2010
  • Aug 9, 2010
Did you measure the thickness/differences of the ring gears?
The depth you want is calculated by the etched dimension on the pinion itself.
The diameter of the pinion is determined by the ratio. It does have an impact on height.
Different manufactures sometimes have different pinion depths.
R
rockyracoon
874
27
49
margate NJ
Aug 9, 2010
  • Aug 9, 2010
yeah but these are ford racing gears,they dont etch a checking distance on their gears.
347HO
462
Seattle
Aug 9, 2010
  • Aug 9, 2010
That's a bummer.
Just another reason not to use Ford Racing Parts.
I assume you measured your original pinion depth before removing it, knowing Ford Racing doesn't etch their suggested pinion depth?
You could check your method this way?
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
