Pinion snubber?
  • Thread starter Thread starter BYRDPE
  • Start date Start date Mar 31, 2008
BYRDPE
1,556
Memphis,Tn.
Mar 31, 2008
  • Mar 31, 2008
What exactly does it do and how does it do it? I read that it helps stop wheel hop but how?
I have also saw the adjustable ones and I was wondering when does one need an adjustable one to replace the stocker?
Also, what steps are taken to set an adjustable one up properly?
BTW....my car is lowered using FMS B springs.
Thanks
dcurtis
688
Mar 31, 2008
  • Mar 31, 2008
A pinion snubber keeps the axle, or rear end from traveling upward in hard launches, or keeps it from twisting and throwing off your pinion angle on launches, they are a good item to add if you don't have one.
BYRDPE
1,556
Memphis,Tn.
Mar 31, 2008
  • Mar 31, 2008
How do I set one up? Same height and clearance as the stocker?
Thanks
Saleen8786
209
Marlton, NJ
Mar 31, 2008
  • Mar 31, 2008
i got one with my eibach drag launch kit,dont know if you can buy separate from eibach worth a ****.
R
Fox Hydroboost conversion/proportional valve
  • RubyRedNotch
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
RubyRedNotch
R
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
D
AOD TV cable replacement bushing - loose pin?
  • DuluthFoxbody
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2026
DuluthFoxbody
D
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 9:17 AM
keel
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
