  • SN95 4.6L Mustang Tech
pinion torque?
  • Thread starter Thread starter SpazLE995
  • Start date Start date Apr 17, 2006
SpazLE995
22
  • Apr 17, 2006
What is the torque on the pinion when testing the pre-load?
I am not talking about the torque need to crush the sleeve but the torque needed to rotate the pinion after crushing the sleeve.
It should be in In/lbs
Thanks in advanced-
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Apr 17, 2006
  • Apr 17, 2006
around 26-27 in/lb's for new bearings
M
mijo_latino
179
Canton, Michigan
Apr 17, 2006
  • Apr 17, 2006
used bearing 8-14 in/lbs
new 16-29in/lbs
make sure to take off wheels and brake calipers.
O
8.8 Pinion Nut Leak
  • OX1
  • Jan 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
OX1
O
O
Progress Thread LTD-ing
  • OX1
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2026
OX1
O
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
Cobra 8.8 differential rebuild shop question
  • Sestemybe
  • Aug 5, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 15, 2025
baileygruwell
