Pintle Cap
  • Thread starter Thread starter aNotchAbove
  • Start date Start date Apr 22, 2007
A
aNotchAbove
75
  • Apr 22, 2007
I cracked one of the pintle caps on an injector when I was swapping my heads/intake and was wondering if it was possible to run the car without a cap on one of the injectors. I want to get my car to the body shop tomorrow, but no one around here sells the caps. Thanks!
sawbones25
1,318
Virginia
Apr 22, 2007
  • Apr 22, 2007
You don't have your location listed. Where do you live? Maybe someone close-by might have one...
bill302
2,131
alabama,gadsden
Apr 23, 2007
  • Apr 23, 2007
do you have a napa auto parts near they have what you need click on link below.....
http://www.napaonline.com/masterpag...ber=212085&Description=Fuel+Injector+Seal+Kit
A
aNotchAbove
75
  • Apr 23, 2007
Im in Canada, just outside Toronto. Had zero luck with the local Napa. Would driving it 5min to the body shop hurt anything?
Mustang78
486
Aberdeen, WA
Apr 23, 2007
  • Apr 23, 2007
it should be ok, i've seen a few toyota pickup 22R's built with those caps broken or missing, it might be a heat shield..i have 5 stock injectors for sale if you're interested, PM me...
~Mark~
HISSIN50
34
129
Apr 23, 2007
  • Apr 23, 2007
The caps are there to keep the injector clean (from fogging).
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 23, 2007
  • Apr 23, 2007
Fuel injector seal kits with 2 O rings and a pintle cap (Borg-Warner P/N 274081) are available at Pep Boys auto parts. Cost is about $2.74 per kit.. The following are listed at the Borg-Warner site ( http://www.borg-warner.com ) as being resellers of Borg-Warner parts:
http://www.partsplus.com/ or http://www.autovalue.com/ or http://www.pepboys.com/ or http://www.federatedautoparts.com/
Most of the links above have store locators for find a store in your area.
Use motor oil on the O rings when you re-assemble them & everything will slide into place. The gasoline will wash away any excess oil that gets in the wrong places and it will burn up in the combustion chamber.
The pintle caps fit either injectors with a pin sticking out the injector end or 4 with more tiny holes in the injector end
The pintle caps hold the O ring in place and keep it from sliding off and into the manifold. If the correct pintle caps are used, they do not have any effect on the injector spray pattern.
Heating the pintle caps in boiling water makes it much easier to install them.
kpack5982
Yeah, it was pretty stiff, but eventually a buddy
Jul 13, 2005
325
Granger, IA
Apr 23, 2007
  • Apr 23, 2007
I've run an injector without a pintle cap for about aweek before I could get to a parts store. Worked fine and no damage done (at least not as of right this moment)
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
T
  • Locked
Digital Tuning A9l issue or something else
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 11, 2025
T
Fuel Looking for a little guidance
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 12, 2025
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
