  • 1994 - 1995 Specific Tech
PIP sensor
  • Thread starter Thread starter DDSTANG94
  • Start date Start date Aug 13, 2008
DDSTANG94
465
FRASER, MICHIGAN
Aug 13, 2008
  • Aug 13, 2008
where do u find one...and how do u replace it?
HISSIN50
34
129
Aug 13, 2008
  • Aug 13, 2008
It's called an ignition stator.
It's often easier to get a reman'd dizzy. To remove the PIP, you need to remove the gear on the dizzy. This generally requires a bearing splitter and a puller. It's more than some folks want to do.
DDSTANG94
465
FRASER, MICHIGAN
Aug 13, 2008
  • Aug 13, 2008
ok got cha.... thanks! , any recommendations on a good dizzy
HISSIN50
34
129
Aug 13, 2008
  • Aug 13, 2008
Most folks use the parts store reman'd version (some of the expensive aftermarket dizzies have stator issues, ironically).
When you look for them, be sure you get the right one. Often asking for a dizzy for a t-bird with a 5.0 (search for which years had a HO 5.0) yields better results. Otherwise they sometimes give ya the wrong one (due to bad cross referencing).
The reman companies test the dizzy and if the PIP tests ok, they leave it in there. Who knows how long it will last (that's why the reman'd dizzies often have a lifetime warranty). A tell of it being an old PIP is that there is not an empty hole near the roll pin (near the gear). If there's not an empty hole, that dizzy might have same PIP that it had when it was exchanged last time.
If there is an empty hole, that suggests the PIP was replaced.
The reason for this is that the reman' companies often drill a new hole after replacing the PIP. It takes less time to do that then to line up the old hole.
DDSTANG94
465
FRASER, MICHIGAN
Aug 13, 2008
  • Aug 13, 2008
kk thanks
Engine Defective PIP sensor ?
  • bock
  • Sep 5, 2025
2K
Fox 5.0 Mustang Tech Oct 11, 2025
Mindseye007
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Need help ordering a oil cooler and filter relocation kit but don't know what I need
  • Aiden Brown
  • Aug 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 14, 2026
squeak93
