piston to valve clearence issues?
  • Thread starter Thread starter sheff2720
  • Start date Start date Feb 23, 2004
sheff2720
182
Horsham, PA
Feb 23, 2004
  • Feb 23, 2004
in about a month or so im going to be putting on a set of ported e7s with bigger valves (1.94/1.60).. im a little worried that im going to have some clearence issues.. when i put the heads on im going to check the clearence anyway just to be safe but id rather it not be an issue where i have to change the set up or cut the pistons alittle.. do u guys have any suggestions on what cam to get, or atleast limitations on what might be to big? thanks for the help
thumper460
3,022
Orange Park , Fl
Feb 23, 2004
  • Feb 23, 2004
2720.. the stock Ford pistons are cut for a 1.85 intake, the 1.94s are going to be just a tad too big, BUT.... If you take a die grinder and just "lay back the top of the valve notch", you'll be fine!! the depth of the notch is ok, just the top.... as the 1.94 will be just to the out side ...cool??
Just me.........................
Thumper
sheff2720
182
Horsham, PA
Feb 23, 2004
  • Feb 23, 2004
Thumper
any way around doing this?
sheff2720
182
Horsham, PA
Feb 23, 2004
  • Feb 23, 2004
ttt
thumper460
3,022
Orange Park , Fl
Feb 23, 2004
  • Feb 23, 2004
Yeah... clay the top of the piston and see what you have... then go to lift and duration for the clearance you have... also the intake centerline !! Its Cake!! just try and not make it harder than it needs to be....cool??
Thumper
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
